Stock lines with c5 and ls1 brakes work?
Old Nov 20, 2009 | 01:04 PM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
Doing the front c5 brakes and rear ls1 setup real soon, and want to know if the stock lines will fit or screw in while I upgrade them? I do want to get the Earl's lines, but just want to know if I should buy Earl's 3rd gen lines, or get the c5 front lines and rear ls1 lines. Thanks guys!
Old Nov 20, 2009 | 03:03 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Stock lines with c5 and ls1 brakes work?
Your front lines will probably work. I had some braided lines on the stock front brakes before I went with the C5 setup, and used those same lines.
I can't answer for the rear, I had the cast iron calipers with hard lines attached to them. I had to cut and flare them to fit my LS1 brackets for the flex lines.
Old Nov 20, 2009 | 06:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
earls 3rd gen lines for a later model 88 and up i think with the pbrs will work. However, i dont think earls makes the lines anymore.
Old Nov 22, 2009 | 07:59 PM
Oh ok, so the stock lines should be ok too? Thanks guys!
Old Nov 22, 2009 | 09:18 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
How about posting the links for this fine modification?
I'm doing my brakes soon
Old Nov 22, 2009 | 09:41 PM
Al Hasse's Avatar
For the rear LS1 setup, stock LS1 lines or braided replacement LS1 lines will work on a 4th gen rear. A 3rd gen rear being about 2" narrower on each end makes for a nasty bend in the flex line. I had some made locally at a hydraulic hose shop.
Blind Driver, a couple of links to my upgrades, they've been posted before.
Front C5.
http://cascadecrew.org/phpBB2/viewto...ghlight=brakes
Rear LS1 starting from 10.5" disc with cast iron calipers.
Old Nov 23, 2009 | 10:27 AM
I'm just waiting on getting all the parts together to spend a weekend on the mod. I'll document my progress and post it on here.
I also have a bender and I can easily get a flaring tool from my buddy who owns a crapstang shop. It'll probably be easier to to take it to his shop so I can use his lift. He'll let me use it no charge for as along as I want.
Old Nov 23, 2009 | 06:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
atre you planning to get a 4th gen rear, or just swap the brakes? If you are just swapping the brakes, depending on what you have now, disc/drums, your hardlines may need modification.
the 3rd gne drum lines are too long, and need to be shortened, or carefull bend a loop in them to shorten them. Also, IIRC, the 3rd gen pbr disc flex lines are 2 different sizes, one longer than the other. They will still work, but i dont think they will fit into the 4th gen brake brackets that connect ot the LCA mount and hold the connection of the flex lnes to the hard lines.
Old Nov 23, 2009 | 08:34 PM
I probably should have described my current setup in the begining, lol, sorry. I'm keeping the stock rear, so I'm just swapping brakes and I do have drums. I actually found a complete 4th gen rear brake setup from a 2000 z28 off of ebay for what I thought was a great price: calipers (with good pads), rotors, lca brackets, e-brake cables, flex lines, and backing plate. Yeah, I figured I had to modify the hard lines in the rear, which is no problem. The only tool I really need to do brakes is the flarring tool. I think my real concern is with the stock lines up front fitting on the c5 calipers. What do you think? You guys are awesome! Thanks a bunch.
Old Nov 23, 2009 | 08:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the front lines will work just fine, stock rubber or aftermarket stainless braid. They connect with banjo bolts, just be sure to use new crush washers
Old Nov 23, 2009 | 09:01 PM
Al Hasse's Avatar
Probably the same setup I bought last year, probably the same seller too. The flex lines are just a tad too long for a 3rd gen rear. The ones I had made are the same length, but have a 90* fitting on them so that the bend they make isn't so radical.
Old Nov 23, 2009 | 09:18 PM
Ahh, will do! Thanks again. You're the man!
Old Nov 23, 2009 | 09:20 PM
Yeah, the seller had a few of these sets available, I was quite impressed with how good a condition everything was in. I'm thinking of having the calipers powder coated.
Old Nov 24, 2009 | 06:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
probably the same guy i bought mine from too
Old Nov 24, 2009 | 07:15 PM
Al Hasse's Avatar
Trans Am Creations run by seller firehawkjeff. One of my backing plates came with a broken e-brake lever, I called them and had them send me a new lever. I ordered one from Ed Miller here also (just in case), now I have a spare. Overall good product and a rather straight-forward conversion for me. I would order from them again. I cleaned the calipers real good and painted them red with caliper paint.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
dbrochard
Sep 19, 2015 08:13 PM
64goatman
Sep 9, 2015 01:09 PM
