Rear PBR overhaul
Old Jan 11, 2010 | 04:15 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Rear PBR overhaul
So, I got a set of PBR calipers and axle flange brackets for my 9-bolt. I took them apart just fine, but have a couple of questions on getting them back together.
Firstly, the area between the actual caliper piston and the brake pad piston, do I fill this with brake fluid? Grease? Leave it empty?
Secondly, how do I adjust for free travel? I mean, I know it's the little allen set screw, but what do I adjust for? I'm going to have new rotors + pads when I adjust, so it should be a good adjustment.
Thirdly, how do I recompress the parking brake springs to reinstall them in the assembly? I got them out using a 1/4" drive extension and one of the holes in the bracket, but I don't think that will get them back in.
Old Jan 11, 2010 | 04:53 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear PBR overhaul
Free travel:
https://www.thirdgen.org/forums/susp...ear-brake.html
Spring:
https://www.thirdgen.org/forums/brak...-did-yall.html
JamesC
Old Jan 11, 2010 | 11:04 PM
Axle/Gears: 3.27 BW
Thanks! Anyone know about the area between the piston and the clamp rod?
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
Out-Cast
Aug 17, 2015 10:57 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
