my LS1 homemade brake install
Old Feb 25, 2010 | 10:12 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Old Feb 25, 2010 | 10:30 PM
Re: my LS1 homemade brake install
Old Feb 26, 2010 | 08:29 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
what the torch for?
i hope those are hardened bolts, they dont look it from the pics
Old Feb 26, 2010 | 08:36 AM
Stephen's Avatar
Car: 87 GTA
Straight, cutoff wheel, hand cuts? I'm wondering how accurate cuts like that would be, regarding balance. If if is even slightly larger on one side vs the others, the balance at speed could be very noticeable, like an unbalanced tire would be.
Old Feb 26, 2010 | 11:11 AM
Old Mar 1, 2010 | 12:04 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
Fail.
Old Mar 1, 2010 | 12:21 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Um...is it me or is there a big chunk of metal missing? If so....FAIL FAIL FAIL!
No wonder 3rdgen owners have a rep for being trashy hack jobs who wear ******s listening to Whitesnake...
That is beyond shady tree backyard mechanics, that's beyond a safety issue.
Please stay away from Philly, I won't want you to lose a wheel and crash into my non-hack job car.
Old Mar 1, 2010 | 03:33 PM
chevy2ss's Avatar
Car: 63 Nova SS, 91 Camaro Rs
holy **** lololol and here i thought all the funny left thirdgen years ago.
Old Mar 1, 2010 | 04:18 PM
Car: '88 GTA
Engine: L-98
Originally Posted by skirkland1980
i used the torch to cut out the brackets. all the bolts are grade 8. i don't think the hub will be out of balance. i think the symmetrical cuts are mostly cosmetic. nobody would buy a hub that looks like it was cut by hand. if i have a problem i'll just make another one. thanks for the feedback guys.
I'll be constructive.
Take those hubs and throw them in the trash. You're at the worst going to kill yourself/someone else or at the least going to have a nasty vibration.
Put the stupid cutting torches and grinder away. Put your new hubs on a lathe and do it the right way. There is a reason that every person thats done the hybrid brakes has a round hub. Look around, you're the one kid thats not like the other....
Looking at the hubs makes me wonder what the spindles look like.
Seriously, take this advice.
Old Mar 1, 2010 | 04:28 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
yeah I wouldn't feel safe with those "hubs" I would definitely do them the right way!
Old Mar 1, 2010 | 04:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
aside from the weird hexagon shaped hub, there isnt enough metal left around the wheel studs for my taste. That really could come apart. Seriously, modified hubs are 75bux.
Old Mar 1, 2010 | 04:47 PM
Old Mar 1, 2010 | 05:00 PM
Car: '88 GTA
Engine: L-98
thanks for all the feedback. that one hub was mainly for mock-up. on the other hand i'm sure the department of transportation would not approve any modification of this caliber to the brake system anyway. if someone has the credentials i'd like to see them. the only way i could see this being approved by DOT is an entirely new spindle with the caliper mounting pad cast in. for those children who are members of this forum (and only the children, you know who you are) don't worry. one day you may mature into an adult.
You might want to refer to what the 1LE spindle modification is before jamming your entire foot up to your calf in your mouth.
Old Mar 1, 2010 | 05:59 PM
Old Mar 1, 2010 | 06:09 PM
Car: 89 formula 350
I think its more blunt advice than anything. "Mock up" or not....get those things into the trash....they are unsafe!
Old Mar 1, 2010 | 06:23 PM
Old Mar 1, 2010 | 06:29 PM
Car: '88 GTA
Engine: L-98
thank you for your advice and i will do the hubs the right way. why are you being such a child with your remarks?
I'm really not much for beating around the bush. Just calling it how I see it.
For reference, I did this exact upgrade on my own to my own car using info provided on this board. Always do your homework on mods, and just about when you think you know everything there is to know about a mod, go ahead and research some more. You will save time and money.
Old Mar 1, 2010 | 06:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
thank you. if those other guys can't post replies with helpful advise they don't need to be here.
you really need to take a set back, take a deep breath and relax. We are trying to help and offer helpful advice. we dont want to see you hurt yourself or somebody else with a poorly modified part. Just looking out for you.
Old Mar 1, 2010 | 08:38 PM
Old Mar 1, 2010 | 09:33 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Some things are worth paying for,..... In this example we all in agreement; play it safe and pay for the hubs.
If your going to drill/tap the holes in the Spindles to accept larger bolts for the caliper brackets - be sure that they are drilled/tapped at the proper angle......... If not the caliper mounting bracket will not sit properly when mounted in relation to the rotor. Then the caliper is wrong, the pads are wrong, and catastrophic brake failure is imminent.
Old Mar 1, 2010 | 09:55 PM
Old Apr 12, 2011 | 10:14 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
just doing a search....all the brake threads are just great... and then.....wow. what a **** job.
dude. its unsafe, ****, and you're too damn uneducated to understand why.
end of story.
so a year later, how did this end? did darwin win yet? LOL.
Old Apr 12, 2011 | 10:44 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Old Apr 12, 2011 | 04:59 PM
end of story.
obviously you and everyone who made a bs reply are too uneducated or lazy to read the entire thread so i deleted everything. Thanks
Old Apr 12, 2011 | 06:18 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
uhh.. no... if all of the pictures were like the one someone saved before you deleted them. you are driving a death trap.
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
