rear brake lines
Old May 2, 2010 | 10:06 AM
92yellowcamaro's Avatar
Car: 1992 camaro rs, 1988 saab 900
Engine: 305 tbi 5.0L V8
rear brake lines
Hey all,
Just put a posi in my car yesterday, went by pretty well. After bolting everything back together i went to bleed the brakes, but my one line on the rear from that junction box to the passenger side brake has a pin hole and leaks ever so slightly, question is can i get hard line from a dealer or are their after markets pre-bent ready to put on. I would like to stay away from bending my own line but if it has to come down to that i will.
-Zach
Old May 2, 2010 | 10:25 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: rear brake lines
Almost positive your going to have to just get a straight piece. The line should be almost a straight shot from the Tee to the brake, not any significant bends. Just meausre how long it is and get the piece of line that is the closest in length without being too short.
Old May 2, 2010 | 11:12 AM
thought that was going to be the case... thanks
if anyone else has input let me know
thanks
Old May 2, 2010 | 01:22 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Normal parts store you just have to get a straight piece and bend it. I went with some stainless ones from http://www.finelinesinc.com/ that were already pre bent. A lot more pricey than straight brake line, but still not too bad.
Old May 2, 2010 | 01:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Along with the above site, there are others that you might consider:
http://www.classictube.com/
http://www.inlinetube.com/
BTW, I purchased mine from finelines.
JamesC
Old May 2, 2010 | 02:04 PM
Thanks for the links, i know where to go now
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
