pics of 9-bolt
Old May 2, 2010 | 06:28 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Transmission: auto & t5
pics of 9-bolt
i was wondering if anyone has any pics of a 9-bolt with the delco morina calibers. i took the rear all apart to paint a while back and i dont rember how the brake lines conect to the calibers. i dont belive i bent the line any, i have the center bolted down and the passanger side to the caliber but the driver side doesnt look right. any help would be much appricated.
Old May 2, 2010 | 06:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: pics of 9-bolt
IIRC, same as the 10-bolt. The pass side should have a flex line to the caliper, the driver's side a hard line to the caliper.
JamesC
Old May 2, 2010 | 07:19 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: pics of 9-bolt
yup thats how i have it but i dont think i bent the hard line at all and it seams like it is way out in front of the axl. i just cant figure it out
Old May 3, 2010 | 07:42 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: pics of 9-bolt
i hope these pics could help out with what i am talking about. something just doesnt seem right to me . if anyone could help me out it would be greatly apprecited . thanks in adavance.
Old May 3, 2010 | 07:47 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: pics of 9-bolt
oh and please excusse the mess i really need to clean my garage.
Old May 3, 2010 | 09:19 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: pics of 9-bolt
JamesC
The 10 bolt I took from an 83 Trans Am didn't have a flex line on either side. The new ones I ordered from lnLine Tubes were the same as what I took off, they were ordered specific to year. I've since removed those brakes in favor of LS1 discs.
IIRC, that line needs to go under the axle after running in front of the spring perch, then it makes a 180* bend to connect to the caliper. That bend is almost there in your pic.
Old May 4, 2010 | 01:44 AM
Red87SC's Avatar
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
Re: pics of 9-bolt
ill see if i can crawl under my TA tomorrow and snap a pic of it for you!
Old May 4, 2010 | 06:20 AM
JamesC's Avatar
Re: pics of 9-bolt
Since the OP is discussing a 9-bolt, I didn't think that would be an issue.
JamesC
Old May 4, 2010 | 07:20 AM
Al Hasse's Avatar
Re: pics of 9-bolt
You're right there. However, that driver side appears to hook up just like mine did by routing under the axle after passing in front of the spring perch.
Old May 4, 2010 | 08:31 AM
Twin_Turbo's Avatar
Re: pics of 9-bolt
Maybe this pic will help, hard to see the line but it's there.
The sharp 90 deg bend that sits on your chock mount, just left of the blue rag actually sits lower, on the shock mount and the rest of the line passes under the spring perch and to the caliper
Old May 4, 2010 | 08:34 AM
Twin_Turbo's Avatar
Re: pics of 9-bolt
I actually have a better pic:
Old May 5, 2010 | 08:42 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: pics of 9-bolt
that pic works perfect for me . thanks for the help guys yall are the best . i just couldnt figure it out and i didnt want to kink the line trying to bend it .thanks again everyone
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
ndndndnd
Sep 28, 2015 08:00 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
6speedIROC
Sep 13, 2015 01:29 PM
