trouble with rear rotors
Old May 24, 2010 | 10:37 PM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Transmission: 700r4 built
Axle/Gears: 3.42 posi 10 bolt
Well I almost have my swap done, but I ran into a issue. I put a 97 z28 rearend into my car. Everything went together good until now. When I installed the wheel and torqued it down the wheel will not turn unless forced I took it off and the rotor will then turn freely. So I put lug nuts on just the rotor and same issue, I noticed the nuts pushed the rotor into the inner calliper bracket. I have new rotors "and made sure they were right", calipers, and pads everything was bought for the 97 rearend. So now im stuck any help would be nice.
Old May 26, 2010 | 07:23 PM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Re: trouble with rear rotors
Ok I might have ii figured out now. Does anyone have a picture of how the lt1 calipers bolt on to the rearend. I have found some on here but there to far away to tell.
Old May 26, 2010 | 09:17 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Various pics in the following link:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old May 26, 2010 | 09:54 PM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Thanks. Thats how I have my caliper bolted is on the out side of the axle flange, but the rotor is still hitting the caliper bracket??
Old May 27, 2010 | 06:50 AM
JamesC's Avatar
And so your set-up looks, generally, like the one in the following pic--axle flange, backing plate, caliper carrier (in red), caliper?
https://www.thirdgen.org/forums/atta...s-89-shims.jpg
If so, are you absolutely sure that everything is set-up for a 97?
JamesC
Old May 27, 2010 | 09:57 AM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Yes, well I bought new calipers rotors for a 97 and the new ones match the old ones exact. the only thing I don't have is the spacer, but I shouldn't need it being a 97 rearend already. Its hard to tell by the picture but doesn't the caliper bracket "the red part" mount towards the rotor or on the back of the flange. "I don't see how it would work if it was mounted on the flange towards the diff".
Old May 27, 2010 | 10:07 AM
JamesC's Avatar
The caliper bracket mounts to the backside of the backing plate (which mounts to the axel flange). Another view:
https://www.thirdgen.org/forums/atta...89-rebrake.jpg
JamesC
Old May 27, 2010 | 10:16 AM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
Ok I go try it but I cant seem to get it to mount from the back side. I'll go take some pictures also. Thanks James.
Old May 27, 2010 | 10:46 AM
JamesC's Avatar
I think we may have confused each other (or just me). Check post #6 for a pic. Note where the red is on the backing plate:
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
Old May 27, 2010 | 11:21 AM
hardyz13's Avatar
Car: 85 Firbird
Engine: 406
This is how I have it set up.
Old May 27, 2010 | 11:31 AM
JamesC's Avatar
While I'm not familiar with fourthgen backing plates, the set-up looks good to me.
JamesC
Old Apr 20, 2011 | 07:30 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Did you get it worked out? I'm having exactly the same problem and it doesn't seem to matter whether I'm using the 3rdgen or 4thgen backing plates.
It looks like the rotor needs like a 1/32" spacer between it and the hub.
Old Apr 20, 2011 | 07:42 AM
JamesC's Avatar
Hey, Dante,
Is it a question of centering the carrier over the rotor?
JamesC
Old Apr 20, 2011 | 04:19 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Originally Posted by JamesC
Hey, Dante,
JamesC
Possibly? The rotor isn't centered between caliper/bracket.
Old Apr 20, 2011 | 06:21 PM
JamesC's Avatar
If the carrier needs to be moved outward for the rotor to be centered, a shim behind the backing plate should do the trick. Check above for pics.
JamesC
Old Apr 20, 2011 | 06:37 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Are you talking about a backing plate shim or a rotor shim? Based on the prob I'm having, the rotor HAS to move outward slightly to clear...
Note my edit above.
Old Apr 20, 2011 | 08:44 PM
JamesC's Avatar
10-bolts with PBR's sometimes had shims behind the backing plates, which moved the carrier outward in order to center the carrier over the rotor--this from the factory. I'm unsure what might be causing your issues. Perhaps someone else will chime in.
JamesC
Old Apr 21, 2011 | 06:34 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
JamesC
This setup has a shim between the backing plate and axle housing. If I remove it, it would probably give me the clearance I need. Is there a problem to do this? I can't see why there would be, but....
Old Apr 21, 2011 | 07:04 AM
JamesC's Avatar
No problem in removing the shim. Some cars are equipped with one, some with two, some with none. My car only required one. (The shims come in a couple of different thicknesses from the factory, IIRC.)
BTW, I've read that 9-bolt weren't equipped with shims at all.
JamesC
Old Apr 21, 2011 | 09:20 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Add or remove shims until the rotor is centered in the mounting bracket. Changing shims requires removing the axles, which sucks. If the caliper is not perfectly centered, pad wear will not be even. My rotor was too close to the inner side of the mounting bracket and my car made a weird ringing noise (like a rung bell) when I made left turns due to the rotor rubbing on the caliper bracket . Lateral axle movement caused this.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
