emergency brake
emergency brake
I just got back from the mechanic
and the engines beautiful.
But he could not fix the e brake,
he said he couldn't find the part, but that he didn't think to check yearone,
but when I go to check, i don't know what i'm looking for
he said its no cable problem at all, it even looks like the owner before me had put in new cables,
that it must be a ratchet or clank problem?
can anyone help me out in finding the part?
and the engines beautiful.But he could not fix the e brake,
Re: emergency brake
I have check yearone and I have found this,
http://www.yearone.com/serverfiles/f...300&cat=G&trk=
I recognize the ratchet mechanism, I remember the mechanic saying that,
but what about the grip? is that something I would need to? or is the grip the lever? which I doubt.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: emergency brake
JamesC
Re: emergency brake
Posting year, make, and model is helpful for those answering questions. The following is for 82-89 cars:
1. Raise and safely support the vehicle.
2. Remove the adjusting nut at the equalizer (mounted in the tunnel above the drive shaft) and remove the front cable from the equalizer and bracket.
3. Lower the vehicle.
4. Remove the upper console and lower console rear screws. Lift the rear of the lower console to gain access to the parking brake control.
5. Remove the pin and retainer from the control assembly and front cable.
6. Remove the cable and casing from the control assembly and bracket and remove the cable and grommet from the vehicle. Remove the parking brake lever mounting bolts and remove the assembly.
7. Installation is the reverse of the removal procedure. Adjust the parking brake.
BTW, I think there's a certain fear when an owner starts working on his own car, but doing your own work is incredibly satisfying. That said, the purchase of a shop manual or a Chilton's will provide useful guidance.
JamesC
JamesC
Re: emergency brake
90-92
1. Remove the carpet finish molding.
2. Remove the console assembly.
3. With the parking brake lever in the down position, rotate the arm toward the front of the vehicle until a 3mm metal pen can be inserted into the hole. Insert the metal pin into the hole, locking out the self adjuster.
4. Raise and safely support the vehicle.
5. Disconnect the rear cables from the equalizer.
6. Lower the vehicle.
7. Remove the barrel-shaped button from the adjuster track.
8. Remove the parking brake lever mounting bolts.
9. Remove the front cable and casing from the control assembly using a fabricated parking brake cable retainer compressor tool.
10. Install is the reverse of the removal procedure. Cycle the lever to set the parking lever and cables in their proper location.
JamesC
JamesC
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: emergency brake
Manual: Unscrew it.
dbrochard
Sep 19, 2015 08:13 PM
