brake calipers for LS rear
Old Aug 18, 2010 | 08:30 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
If the answer is already here I didn,t see it so I will ask it. I got a 2000 LS rear zexel torsen posi track recently but it was stripped of all braking components except the part you bolt the backing plate to. I have found ( I hope) a 96 or so s10 and s10 blazer with disc brakes on the rear. Is there anyway that I can use these?
Old Aug 18, 2010 | 08:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: brake calipers for LS rear
why not use the correct brakes?
Old Aug 18, 2010 | 09:42 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thats easier said than done around here. If I could afford the new LS calipers and setup then I wouldn,t have this problem.
Old Aug 18, 2010 | 09:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
not saying new, you can usually pickup the complete brake setup off ebay for around and under 100bux. It will bolt right on, no headaches of trying to retrofit something, that has to be worth something. Its a pretty nice set actually, and the parking brake is good too
as for the blazer brakes, i dont know what they style backing plate they use, and the axle lengths and such. if they are free parts, you could give them a try and see what happens.
Old Aug 18, 2010 | 09:50 PM
NovaScotiaRS's Avatar
More than likely you will need to remove that remaining piece. The S10 axle should have the same bolt pattern as the 4th gen axle. 10 to 1 you will need everything and will have to discard the remaining brake part on the 4th gen axle. The only concern I would have regarding bolting up is the dimension from the axle flange to the hub face.
Old Aug 19, 2010 | 12:54 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
the flange is the same for all disc cars from 82-02. can be done but its a slightly smaller rotor. still an upgrade from drum. lol. where are you located that its hard to get parts if i may ask?
Old Aug 19, 2010 | 09:35 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
I am in Hattiesburg Ms. The junk yards around here crush everything over 10 years old and most thats over 7. Except the ones in the outer limits and they have been picked over. Like I said its tough down here.
Old Aug 20, 2010 | 12:46 AM
Car: 91 formula ws6
Transmission: 4l60E
geesh. the yards up here keep everything. lol. try ebay and craigslist. thats were i got all 4 wheels worth of brake parts from a 2002 camaro for 200. calipers, rotors, pads, all nuts and bolts, e brake cables, etc. deals are there you just gotta hunt.
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
Reddeath210
Oct 6, 2015 08:20 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
