Is 200 a good price?
Old Nov 2, 2010 | 04:26 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Hi I was curios if 200 was a good price for a posi with disc brakes rear end. I found a guy selling one who said it is complete. Right now I have a drum rear end
Old Nov 2, 2010 | 04:29 PM
Project-RS's Avatar
Re: Is 200 a good price?
i paid 150 for a complete setup, but you might want to check into brake boosters and lines. i believe you need to run more. others will know more. i have aluminum drums on my posi for now.
Old Nov 2, 2010 | 04:33 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Was that 150 for POSI drum setup or POSI disc?
Old Nov 2, 2010 | 04:37 PM
Project-RS's Avatar
posi disk. will be doing the install next spring
Old Nov 2, 2010 | 04:51 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
150 then seems like a real good deal. I was pricing parts just to convert my rear to disc and it was a lot. I may try to haggle with guy a little. Is there anything special you have to do if your existing gears are different then the rear end you are swapping?
Old Nov 2, 2010 | 04:58 PM
Project-RS's Avatar
i went from 273 to 373 rear gears and i havent noticed a difference, but then again i havent really paid attention to much either. ill get more info
Old Nov 2, 2010 | 05:19 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
I did not think it mattered. I thought it may change speedo, but guy who I want to buy from said it does something to rpms
Old Nov 4, 2010 | 11:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the gear ratio is the same, no problem, however, if it's different you'll have to swap the drive and/or driven gears to make the speedo function correctly. There are other matters to consider as well, such as the combination valve and parking brake cables. The following link should get you up to speed:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
okfoz
Mar 9, 2017 02:35 PM
Reddeath210
Oct 6, 2015 08:20 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
