12-13 inch rotors for 87 iroc
Car: 89 RS,02 WS6 M6,08 GMC Sierra SLE
Engine: ZZ4HCI, LS1, LY5
Transmission: T5/T56/4L60E
Axle/Gears: 323,342,373
Hey guys i was just wondering if theres a caliper bracket out there that would allow me to run a 12-13inch Baer rotor in the rear using the stock calipers from my 87 iroc rear end or any kind of 12-13 inch rotor whatever would fit between the binders would work too. I planned to use a Bear kit in the back(currently using Baer Alcon Pro4 upfront ) but money is tight right now and the stock calipers work fine. If someone has part numbers to refer me to or point me in the right direction i would greatly appreciate it.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 12-13 inch rotors for 87 iroc
Actually i just found that ed sells the brackets to run a 12-13 inch disc in the rear if anyone intends to run that set up. If anyone needs i can post the part numbers. These are with the stock calipers.
keep in mind these are meant to be used along with the 9bolt borg and warner stock rear ends.
-Item #9BoltBkt12
-Item #9BoltBkt13
-Item #9BoltBkt12
-Item #9BoltBkt13
Not if you want to use the cast iron calipers, if you want to use the PBR aluminum calipers then yes, it can be done..on a 9 bolt too. Ed Miller has the brackets. I have a 13/12 fr/rr baer system
Ed sells the backing plates for a ten-bolt as well, but again only for use with PBR's (89-97). The Delco-Moraine iron calipers (82-88), as Twin mentions, won't fill the bill. If you should ever wish to upgrade to PBR's, the following link may be useful:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
JamesC
Hmmm the discription for the products isnt very clear.
- 12 inch "Hassle free"rear disc conversion brackets
NEW! These conversion brackets allow a simple bolt on conversion to 12" GM style PBR LT1 rear disc brakes. Installation hardware and instructions are included, removal of the rear axles is required, no axle modification is needed.
Item #HFConvBkt12
Is the only one that mentions using PBR's. But im sure you are both right. i already called Ed to change my order im just waiting for him to call or email me back.
Item #HFConvBkt12
These were the 2 i thought still use the stock caliper since they dont mention the use of PBR's and the other does.
Borg Warner 9 Bolt Rear Disc Conversion Plates, 12" rotors
These brackets allow the installation of larger 12" Corvette rear discs on factory disc rears and replace the now discontinued backing plates for third gen F bodies. Zinc plated laser cut brackets and Grade 8 installation hardware are included. Requires removal of axles for installation. For use with stock sized 12" C4 rear discs.
Item #9BoltBkt12
Borg Warner 9 Bolt Rear Disc Conversion Plates, 13" rotors
These brackets allow the installation of larger 13" custom rear discs on factory disc rears and replace the now discontinued backing plates for third gen F bodies. Zinc plated laser cut brackets and Grade 8 installation hardware are included. Requires removal of axles for installation. For use with custom 13" rear discs.
Item #9BoltBkt13
Item #9BoltBkt12
Item #9BoltBkt13
ambainb
Apr 25, 2016 09:21 PM
mustangman65_79
Aug 11, 2015 03:17 PM
