Front Brakes.... NEW IDEA
Old Nov 28, 2001 | 12:00 AM
  #51
cy Z28's Avatar
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
Is it ready for production?
Old Nov 28, 2001 | 07:17 PM
  #52
kiztope's Avatar
Car: 92 Formula
Transmission: A4
How much is this gonna cost?
Any ideas?
http://kiztope.50megs.com
92 Pontiac Firebird Formula WS6 5.7/A4
K&N, Blue Streak Cap and Rotor, strange unknown exhaust system (sounds good though)...
Mods are in direct proportion to income!
92 Rs 3.1/T-5
Beautiful car, many mods, but now I am turning attention to the 'bird!
AIM : Theonekiztope
ICQ: 8787542
"Maybe one day life will take a turn. When it does Lean into it!" Leon Calrinsky (98)
Old Nov 29, 2001 | 01:36 PM
  #53
blown87gta's Avatar
Car: 1987 Pontiac TransAm GTA
Engine: Vortech S-Trim, 355cid
Axle/Gears: Mosier 12bolt, 3:73 Eaton locker
<font face="Verdana, Arial" size="2">Originally posted by kiztope:
Any ideas?
</font>
More than anyone will want to spend.
IIRC, DBA rotors are ~$120each and
the Superlite 6 calipers are in the
$400+ range each. Then there's the
machining of the hubs and the bracket
to adapt the calipers to the spindles...
Like I said - TOO much....
Old Nov 30, 2001 | 09:53 AM
  #54
TVP's Avatar
TVP
then there's the clearance problem with the "little" off-sets on those rotors ... ever notice that 3rd gen's rotors drop in
about 3-4" ... vette and 4th gen rotors only drop in .5-1" .. so the outside of the caliper WILL rub stock wheels ... or you'll have to run spacers or 4th gen wheels .......stand back and look at the WHOLE BIG PICTURE .... there's a perfectly good reason 1LE's look like they do !!!
Old Nov 30, 2001 | 03:40 PM
  #55
blown87gta's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TVP:
</font>
Sorry, I never intended to imply that these
would work with 16" 3rd gen OR 4th gen wheels. I am planning on this "swap"
REQUIRING custom offset 17"+ wheels.
T.
Old Dec 3, 2001 | 09:18 AM
  #56
Road Tech's Avatar
Yes the 6 pistons are pricey , but I also have plans to fit a billet Dynalite so it should bring the kit well under 1K. Terry just wanted the bigger calipers because he has to be different I dont Know of any 16" wheel that will fit with the 6 piston caliper.
...John
Road Tech
Roadtechonline@yahoo
www.roadtechonline.com
Old Dec 4, 2001 | 01:47 AM
  #57
cy Z28's Avatar
Road Tech,
I'm outside D/FW, where is Princeton from here? I'm also interested in the Six piston kit. I'd like to help out if I can with this project. Just let me know if I can be of assistance. cyZ28@prodigy.net
Cody "cyZ28" Young
'84 black on black Z28
355, 5-speed (on the way out. What goes back in, ooohh baby!!)
http://www.geocities.com/mustang_tbird/codypage.html
Old Dec 6, 2001 | 02:51 PM
  #58
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Thirdgens handle better than Fourth gens????
that has not been my experience. My wifes Camaro handles worlds better than my firebird, and that is not simply due to age difference. (88 Formula vs. 97 Camaro) Her car drives like it weighs 1000 lbs less than mine, the body is tighter, handling is more crisp, and precise than my car would ever hope to be stock.
From what I understand, this is due to GM using a "glue" on the welded seams, instead of simply a sealer. There is almost zero body flex, and that is with absolutely NO modifications. I can only wish my car handled that good, and it handles fairly well as it is.....
Old Dec 7, 2001 | 12:04 AM
  #59
cy Z28's Avatar
Almost no body flex?? Are you smoking something???
Have you never pulled into a steep driveway approach?? The body flex in these cars is so bad you can feel it in the seats. The reason that your wife's car handles "worlds better" than your car has alot to do with wear and tear, and wheel/tire selection. Go to any hard core road racer, and they'll tell you that the front suspension on the Thirdgens is far more suited to spirited driving than the Fourth.
"Almost Zero body flex" ...hmm where do I start with this one.. Subframe connectors.. ever heard of them? There's a reason that you put on these little jewels. if the car didn't need some help in that dept., do you think that everybody would make them? Zero body flex is impossible. Look at a winston cup car, With it's ladder frame and tube chassis the car is still subject to torsional forces. Find me a unibody car with no body flex and I'll give show you a car that has far too much metal in it to weigh less than 5,000 lbs.
By the way, what suspension mods have you done on you car, how long since your last alighnment, and finally what size/brand/type of tire are you running?
Cody "cyZ28" Young
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
formula_novice
Aug 18, 2015 08:48 PM
stalkier
Aug 13, 2015 12:59 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
