Rear drum master cylinder on J65 4 wheel discs?
Transmission: World Class T-5
Axle/Gears: BW 3.45
I was doing a search on 1LE brakes and I ran across a GM service bulletin about the early J65, 10.5" 4 wheel disc brakes. It stated that if customers complained about the J65 pedal feel, that the dealer should replace the master cylinder with the one for rear drums.
Anyone know anything about that?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Rear drum master cylinder on J65 4 wheel discs?
Axle/Gears: BW 3.45
I was running 1LE fronts and J65 iron-caliper rears, switched to the drum master cyl as the tech bulletin described. Noticeably less pedal effort to haul the car down than with the J65 master cylinder, and no way I'd swap back. Highly recommended.
Axle/Gears: BW 3.45
BTW, were you happy with the 1LE front/J65 rear combo?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
When I converted, I, too, swapped in the J50 master (along with the correct combination valve) as the 1LE conversion suggests. I don't recall the pedal feeling different, though I did this several years ago. I've since thrown on the so-called 1LE rears. The system is very nice.
JamesC
JamesC
Axle/Gears: BW 3.45
JamesC
JamesC
I've also ordered the ANDYZ28 CD on the subject, to see what he's got to say. Hope it's 30 bucks well spent.
)I used Andy's CD way back when. If you haven't seen the following link, it might prove useful as well:
http://web.archive.org/web/200605221.../1LEbrake.html
JamesC
Axle/Gears: BW 3.45
Enough so that I'd recommend the swap (besides I'm **** enough to like the front and rear calipers to match
JamesC
JamesC
I'm considering a 1LE conversion for the fronts on my under 11K mile '89 (rears are already PBR's). Yes, I know that the stock spindles are easily modifiable. But....I saw a pair of new, in the box, 1LE spindles on ebay a year or so ago, and couldn't stop myself from paying through the nose for them. But I'm not completely sure if that's being **** or simply insane.
On my '83, I think I want to go with the cheap man's braking improvement route. Maybe, braided lines for the front, and the aforementioned J50 MC. We'll see....
Weird that the one I'm willing to spend all the money on, ALREADY brakes pretty darned good, now that I've replaced the original Gatorbacks with Goodyear F1's.
They were very good for street/commuting use, but durability on road course track days was limited.
Axle/Gears: BW 3.45
Axle/Gears: BW 3.45
JamesC
JamesC
Okay, here's the big question. Should I do it myself? This is kind of new ground for me. I've never removed and replaced a spindle for example. It looks fairly straight forward. Was it an easy swap? How much time do you think it took you to swap to 1LE front brakes? Any tips?
JamesC
Axle/Gears: BW 3.45
Yes, do it yourself. At the time, I'd never removed a spindle either and certainly never modified one, but it is, as you say, fairly straightforward. Easy? Well, spring removal/replacement can be dangerous. Time? Depends on how fast you work and how many obstacles you run into--for example the a-arm bolts, one or more, are likely seized to their metal sleeves. Two were in my car. They required an hour or so a piece with plenty of sweating, beating, yanking and cursing (done in French, of course, since it sounds much more dignified). Tips? If you're considering lowering the car, now's the time; now's also the time for struts and/or strut mounts as well as new bushings for the a-arms. Work slowly and carefully. The job isn't rocket science.
JamesC
JamesC
BTW, I usually curse at my cars in Greek. It seems like I'm getting my point across to them better.
Axle/Gears: BW 3.45
Is it better to fully assemble everything before you put it on the car, or is it better to install the spindle and then assemble the brakes? Joined: Aug 1999
JamesC
I'm much happier assembling the components onto the car, one at a time, tightening using an accurate torque wrench and Loctite red formula.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
