rotor sheared?
Car: 1987 Camaro Iroc-z
Engine: 350 carb
Axle/Gears: 3:23 posi
rotor sheared?
I'm wonder if anyone knows how 4 out of 5 lug nuts could have possibly sheared right off while driving?.... rotor and all....
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Re: rotor sheared?
Only thing I could think of is that they were over torqued. Did you or anybody else have that wheel off recently? Hopefully nobody was injured when it happened!
Car: 87 GTA
Re: rotor sheared?
Loose lug nuts will do that, allowing the wheel to move & start shearing lugs. Once one lug goes, that means more force on what it left. I'd actually be surprised to see the 5th one hang one without shearing off too.
http://www.youtube.com/watch?v=kyMDNzhfwn0
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Re: rotor sheared?
I agree with Stephen. I have seen it several times. Even had it happen to me once. Loose lug nuts allow the rim to rock back and forth on the lug nuts. You probably didnt even notice it. Then the studs get fatigued, worn, and hot (from wear) then usually shear off unexpectedly.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: rotor sheared?
the rotor came off too? or did that happen when the car hit the ground after the wheel came off?
Engine: 350 carb
Re: rotor sheared?
haha umm... the whole axle is ****ed. apparently the guy i bought the car from had the wrong size lugnuts on the rims.
Engine: 350 carb
Re: rotor sheared?
The rotor didn't come off, the studs that go through the rotor which are connected to the axle sheared off... I didn't know how else to word it
Car: 87 GTA
Car: 86 Trans Am
Re: rotor sheared?
i was actually thinking this was a front wheel for some reason, but since it appears to he a rear wheels, then yes, the rotors are slide on and can come off, but the calipers would have the be broken off too.
oooo what a mess.
oooo what a mess.
Car: 86 Trans Am
Engine: 350 carb
Re: rotor sheared?
yeah... the 5th lug came off when the tow truck lowered it down lol. I just picked up a rear out of an 88 today and 4 iroc rims. So now I just gotta figure out if it would be too much work to convert the brakes from drum to disc...cause I currently have drum...but the rear I bought is set up for disc. Hopefully I could just swap the lines and master cylinder..
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
