Vette y2k rims and brake upgrade
Old Jan 24, 2011 | 08:22 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Hello. I have been out of the loop for a while and am trying to find out what i need to finish my brake swap and get it going. I finaly got my rims.. y2k 18 rear 17 front. I have a complete set of front vette 13.5 rotors and calipers and a rear set of ls1 brake including the backing plate.
My questions.
I have 2 valves one was from a drum and one was a disc how can i tell them apart?
I have EB miller caliper brackets, I know I also need the special hub, Is there anything else?
Will I need spacers in the rear to match the front width after the new spindles are on? They move the wheel out farther then stock right?
Old Jan 27, 2011 | 09:19 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: Vette y2k rims and brake upgrade
SO I was reading back through some PM messages from a few years ago.
My fronts are C4 brakes. I have the brackets from EB I think the only thing I need are the 1le hub setups. sound right .. anyone?
I also found out I might not need to run spacers on the front, only the rear.
still unclear how to tell which proportioning valve is for disc brakes.
Old Jan 28, 2011 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The two look the same on the outside and there're no part numbers on them that might distinguish them. Sounds like you require either a 1LE valve or an adjustable.
JameC
Old Jan 28, 2011 | 09:01 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
yea I'm not sure if it will even work if it is a disc p valve. One is from a 89 GTA and the other is just a standard 92 drum valve.
Old Jan 28, 2011 | 05:37 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Ok... I found out a little more.
I have a j50 and j65 master and prop valve... one of both setups.
Sould I use the j50 master with the j65 disc rear prop valve?
I read that the pedal feel is better with a j50 master and a disc prop valve.
Old Jan 28, 2011 | 06:42 PM
JamesC's Avatar
That's the set-up I'm using to good effect. Perhaps the following link, toward the bottom, will provide you with brake info that will provide interesting to your project:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
zayne0
Aug 24, 2015 07:22 PM
86White_T/A305
Aug 17, 2015 12:16 AM
