upgrading to 4th gen brakes
Old Jun 21, 2011 | 09:19 PM
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
So i may be getting a donor car - 95' v6 camaro and it has a 3.08 disc rear to my knowledge. I'd like to put it in my '90 rs. I know i need the conversion lines will I also need a different prop. valve? also where can I get an e-brake swap kit?
Tim
Old Jun 22, 2011 | 05:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: upgrading to 4th gen brakes
you shouldnt need to replace any of the hardlines. jsut use the ones off the doner axle as they are and hook them right up to your stock flex hose.
only thing you need are the conversion cables, hawks and flynbye have them. i have both, i liked flynbye's better, they are a little longer.
use a 1le prop valve, or plumb in a adjustable setup
Old Jun 22, 2011 | 05:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you get the rear with the ebrake cables attached, you can connect YOUR cables to the new axle's cables with stainless cable connectors available for a few bucks at Home Depot. Saves a ton of cash, and works fine - mine's been like this 4 years now with no issues at all.
On the prop valve - some swap some don't. If you don't, what could happen is with a stomping hard braking, the rears may lock up before the fronts. But that is desired (to me) - if the rears lock I still have steering! So it's up to you - you could see what happens without a rear disc valve, and decide after the install of the rear.
I'm not sure on the LT1 rears (pre-1998), but the LS1 rears (1998+) you must have 16" wheels to accomodate the larger rotor.
Old Jun 22, 2011 | 06:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
For best brake performance, use the appropriate--or an adjustable--valve.
JamesC
Old Jun 22, 2011 | 06:04 PM
Car: 1990 camaro rs
Engine: 305 tbi
Well I will have a set of rims to put on the back in case my rims dont fit, what if my current E-brake doesn't work? if the other does can I swap out the whole thing or what?
Old Jun 22, 2011 | 06:08 PM
Car: 1990 camaro rs
Engine: 305 tbi
These are what I want?
- http://flynbye.com/catalog/i212.html
- http://flynbye.com/catalog/i172.html
- http://www.hawksthirdgenparts.com/li...ebird-1-2.aspx
Old Jun 22, 2011 | 06:30 PM
JamesC's Avatar
Yes. I'd consider the following:
http://www.flynbye.com/catalog/i199.html
JamesC
Old Jun 22, 2011 | 09:56 PM
Car: 1990 camaro rs
Engine: 305 tbi
what about a prop valve?
Old Jun 23, 2011 | 06:38 AM
JamesC's Avatar
I was suggesting that since flynbye has the first two items on your list, why not buy everything there.
JamesC
Old Jun 23, 2011 | 09:40 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
I have a 1990 that used to have a drum 3.08 rear in it. I swapped it to a LT1 rear with disc brakes. I used Dorman C94264 for my ebrake cables and they fit perfectly.
Old Jun 23, 2011 | 09:56 AM
JamesC's Avatar
Out of curiosity, does your 90 have the tunnel-mounted adjustment piece? I ask because "apparently" cables for 89+ have two designs: the first design (1434 mm which has the adjuster and which is the one I believe you're using) and the second design (1460 mm and which doesn't require the adjuster).
JamesC
Old Jun 23, 2011 | 10:43 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
JamesC
I don't believe it has an adjustment in the tunnel, but I could be wrong. The equalizer is pretty rusted up and I might not have noticed it. I tried to find a pic of what I have, but I could only find a pic of something that I don't have - https://www.thirdgen.org/forums/atta...e-adjuster.jpg
At first I bought the "second design" cables DORMAN C94597, but found that the holes that attach to the caliper levers were slightly too small, the length of cable between the caliper side and the body clip was too short, and the total length of the cables was too long. I was pissed that day lol.
Old Jun 23, 2011 | 11:15 AM
JamesC's Avatar
Thanks for the imput. Interesting as common board wisdom says first design (which I used without issue) with the adjuster pictured above and second design without the adjuster. Perhaps prospective buyers would be well advised to purchase the flynbye spec-built cables and be done with guessing.
JamesC
Old Jun 23, 2011 | 11:18 PM
Car: 1990 camaro rs
Engine: 305 tbi
ok I got the donor car today and it ended up having drum brakes but their not rusted to ****, I was told they're a 3.23 lsd but ill have to check that tomorrow, will this make the swap easier now?
Old Jun 25, 2011 | 06:27 AM
Car: 1990 camaro rs
Engine: 305 tbi
Anyone?
Old Jun 25, 2011 | 06:47 AM
JamesC's Avatar
You won't have to change the combination valve. I'm uncertain about the parking brake cables. If you can get the cables along with the rear, I'd try them first, then go from there if they won't do the trick. Also, remember that a gear change with affect the speedo.
JamesC
sailtexas186548
Jan 19, 2016 12:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
