87 TA Locked Front brakes Backs work fine
Old Sep 19, 2011 | 12:32 PM
jacobmh's Avatar
Car: 87 Trans am
Engine: 327
Axle/Gears: soon 373
Front Brakes are locked up. THis is where we started. I replaced the rear Drums and cylinders about 3 months ago when I put the New Rearend in. After I finished installing new motor I took it for a test drve and came back and smelled the front brakes. Jacked the car up and I could not turn the Front wheels. THe rears work fine I step on the Brakes the tires do not move I release the Tires move. So I replace the 2 Front calipers and the same thing. So I replaced the Master Cylinder still the same thing. If I release the Pressure by opening the bleeder Valve the Brakes release like they should it seems like the Fluid is only going into the Front Caliper and not being able to come out. I guess I only have two parts left. THe Booster but I figured if the booster was sticking then all 4 would lock up. Or the Proporsioning valve????? And help is greatly appreciated. THanks in advance
Old Sep 19, 2011 | 01:39 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: 87 TA Locked Front brakes Backs work fine
THe only thing left that it could be is the proportioning valve.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Fronzizzle
Aug 9, 2015 01:15 PM
