Drums to disc offsets
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Does anyone know if going from drums to disc brakes pushes your wheels out further?
Going from drums to 10.5" disc?
OR
Going from drums to PBR rear discs?
OR
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Drums to disc offsets
Not by any major .amount if at all. The only difference is the thickness of the drum and rotor and they are all about the same
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As 86 mentions, there's no substantial difference. A spacer was used on 16" wheels when GM switched from aluminum to iron drums, which created a .187 size difference. The spacer, however, seems to be hit or miss and essentially unnecessary. Even some disc brake cars received them.
JamesC
JamesC
KO1
16
Oct 15, 2015 05:00 PM
