Brake Cylider Problems
Car: 1985 Camaro Z28
Engine: 350 Crate
Transmission: 700R4 currently
Axle/Gears: Not sure
I have an 85 Z28 that is giving me the worst trouble. At the moment i'm trying to replace the wheel cylinders. No matter how hard I try, I just can't get that stupid clip on the back of it. Is there a special tool of some sort? Any tricks? Suggestions? ism't there a way I can replace them with the ones you bolt into the back of instead of the clip??
Car: check
Engine: check
Transmission: check
Re: Brake Cylider Problems
Can also wedge a block of wood between the axle flange and the wheel cylinder. Then use a hammer and a punch to seat the clip. Or a socket or a piece of pipe to seat it.
RBob.
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I did just this and had no difficulty getting the clip back on after cleaning one wheel cylinder and replacing the other. Use a piece of wood between the wheel cylinder and the axle flange to keep the cylinder from coming back out then work the socket around in sort of a circular motion to get the clip down in place and whack it with an object of your choice to secure it.
Engine: 350 Crate
Thanks for the advice. I have had more problems with the brakes on this car then anything else.
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
[QUOTE=
RBob.[/QUOTE]
i just replaced one yesterday.i used the socket with a c clamp.what a stupid design.the old design with two bolts was much easier.i look forward to swapping in discs.
RBob.[/QUOTE]
Engine: 350 Crate
I managed to get the cylinder on. I ended up using a hammer and punch. I would like to swap to disc. But I've heard it is fairly exspensive.....
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
