9bolt brake swap questions
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
86 9bolt
Lt1 calipes or ls1 calipers do they sell a swap kit or just stick with ebc rear brakes
Can I use dot 5 500+ boiling point
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 9bolt brake swap questions
With 9-bolt backing plates you could install the correct-sized rotors and either 89-92 or 93-97 PBR calipers. Since the LS1's are designed for a 10-bolt, a bolt-on wouldn't be possible without some kind of modification.
JamesC
JamesC
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I found a post awhile saying that the 98+/LS backing plate fit a 9-bolt with just a simple redrilling of the backing plate mounting holes, but I can't find the thread
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
EBMiller makes swap plates for LS brakes, but their production is usually pretty backlogged.
LT1 brakes were the same PBR Caliper as the 89-92 cars got. The only difference is the LT1 calipers have an extra iron dumbbell looking thing hanging off the back that works as a vibration dampener. They're 11.7" discs with aluminum single piston calipers, very effective design. I've been running 94 Z28 rear discs on factory 9-bolt PBR backing plates (found on any 89-92 9-bolt) for 15k miles, and I'm very pleased with them so far. If you're going from '86 discs to LT1 (PBR) style rear calipers, you'll also need a 1LE proportioning valve though.
The big benefit to LT1 over LS1 is that you easily keep your Emergency brake function. IIRC, LS1's are quite tough to get a functioning emergency brake.
-cal30sniper
-cal30sniper
IIRC, Ed makes an LS1 parking brake cable.
JamesC
Car: GTA
Engine: L98/454/M20
Whoops, I was thinking about these three: http://flynbye.com/catalog/c1_p4.html
They're only for PBR/LT1 style setups with different sized rotors though. You might try contacting Ed directly and see if he can make backing plates for a 9-bolt with LS1 brakes. He does make one for Camaro SS brakes on a 9-bolt.
-cal30sniper
-cal30sniper
I will go with lt1 rotors are bigger what's the word with dot 5. Lt1 brakes is a bolt on that's what y'all saing
Pretty much but you do have to remove the axles in order to mount the backing plates and so on. The following link may give you the idea:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
JamesC
Car: GTA
That pics looks very familiar
! I was talking about an LS1 backing plate, BTW. No such rascal that I know of.
JamesC
! I was talking about an LS1 backing plate, BTW. No such rascal that I know of.JamesC
Car: GTA
-cal30sniper
-cal30sniper
http://www.flynbye.com/catalog/i77.html
Car: GTA
JamesC
Car: GTA
From the link I posted above apparently. I'm glad you found it useful. The two plates (and there's a side by side pic above as well) are thirdgen, 9- and 10-bolt backing plates. Both would except the LT1/PBR system. Since the LT1 and LS1 systems are entirely different, I'd expect the plates to be dissimilar as well.
JamesC
JamesC
JamesC
Engine: L98/454/M20
JamesC
JamesC
-cal30sniper
Ok I'm gathing parts for the ls1 brake swap well I just got the calipers I need bracket specs they we
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Hope I`m not derailing the thread, but I`m about to swap pbr rears onto my 10 bolt drum. I`m aware of the cutting and drilling part on the flange, but I just noticed that the backing plates that came with the PBR`s are from a 9 bolt.
Can i still retrofit a 9 bolt disc plate to a 10 bolt drum flange with some cutting/drilling?
Engine: L98/454/M20
With enough cutting, drilling, and welding you can accomplish anything, but it would probably be way easier to just order the correct backing plates from flynbye and get it done right.
-cal30sniper
-cal30sniper
Car: 1986 Firebird
Engine: Swapped 1986 Trans Am 5.0L TPI
Transmission: Gearstar Built Level 2 700r4
Axle/Gears: 3.42 Peg leg / Soon 2.77 BW
DOT 5 is a silicone based fluid and will always feel spongy. DOT 5.1 is regular brake fluid with a boiling point of 518F.
