Chrome brake booster
Old Feb 1, 2012 | 10:37 AM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Do any of you know where I can find a chrome brake booster for my '89 GTA? I'm looking for one that's made for this specific application and not a generic fit one, if you know what I mean. I have searched quite a bit with no luck. FWIW, my car has 4 wheel disc brakes.
Old Mar 25, 2012 | 10:11 AM
dprest68's Avatar
Engine: cammed LS1
Re: Chrome brake booster
Do they maybe make a chrome one for the 4th gen that I could use? Anyone? Any ideas?
Old Mar 25, 2012 | 10:53 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
you take a stock one to a chrome shop and have it chromed.
very few parts inside.
Old Mar 25, 2012 | 02:08 PM
dprest68's Avatar
Engine: cammed LS1
Well, that sounds simple enough. I'll check into it. Thanks.
Old Mar 25, 2012 | 06:58 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
it comes apart sort of like a sending unit is held into a gas tank, simple tap to unlock ring, but if your not careful you could beat the tabs to death, go slow ands don't rush, also it will jump out at ya when lose but its so simple inside ya can't screw it up.
I got a spare one I was going to powdercoat but its such a PITA to change a booster to reach the bolts [let column hang lose and use every extension you got] I haven't bothered
Old Mar 26, 2012 | 09:44 AM
dprest68's Avatar
Engine: cammed LS1
Thanks for the info. Gumby. Yeah, I did notice how much of a PITA the booster is to remove. There were many cus words flying that afternoon!
Old Sep 4, 2013 | 09:04 PM
Shawn Lyons's Avatar
I do have 1 left but its alittle costly look very nice to have i never seen any 1 with it
Old Sep 4, 2013 | 09:23 PM
dprest68's Avatar
Engine: cammed LS1
Thanks for the information Shawn. I ended up going a different route. I decided to paint it semi-gloss black to keep it stock looking.
Old Sep 4, 2013 | 09:35 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Just polish it! It is easy to do while you sit and watch TV or whatever.
Old Sep 4, 2013 | 09:49 PM
dprest68's Avatar
Engine: cammed LS1
Your polished master cylinder looks nice
Old Sep 5, 2013 | 12:30 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
polishing an aluminum master cylinder is a totally different deal than polishing a stamped steel brake booster...
Old Sep 5, 2013 | 02:18 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Yeah I wasn't paying much attention and assumed. In that case just paint it and use clear coat. But don't let brake fluid touch it!
Old Sep 7, 2013 | 04:43 PM
manmaro jew's Avatar
how did you take those bushings off safely?
Old Sep 7, 2013 | 06:54 PM
Tibo's Avatar
Car: 1991 Z28 Vert
I'm not sure what your'e referring to.
Old Sep 8, 2013 | 04:01 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Problem with that is it may need to be rebuilt when once the seals (o-rings) dry out.
Every rebuilt master cylinder I've ever used was a POS so I only use new Master Cylinders. Brakes are too important to take a chance with.
Old Sep 8, 2013 | 06:50 PM
the brake master cylinder you are holding and polishing does not have the plastic bushings in it
Old Sep 12, 2013 | 01:57 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Smart move. Much better idea.
Old Sep 12, 2013 | 02:13 PM
dprest68's Avatar
Engine: cammed LS1
I thought so too. Thanks.
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Sep 19, 2015 08:13 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
