9 bolt w/ disc swap - e brake adjustment?
Old Feb 20, 2012 | 03:54 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
I swapped in a 9 bolt disc, changed the e brake cables but how do i adjust the e brake?
Old Feb 20, 2012 | 08:25 PM
87IROC350's Avatar
Engine: 5.7
Re: 9 bolt w/ disc swap - e brake adjustment?
Been a little while since I've looked at it but I believe there is a threaded connection where the ebrake cables connect to a bracket underneath the car in the area of the transmission tail shaft. You can add or remove play by adjusting the nut on the bracket. Just follow the cables towards the ebrake and you should find it.
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
91 SrS
Oct 7, 2015 04:32 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
FormulaEngland
Sep 30, 2015 01:50 PM
