Which 4th gen master cylinder do I have?
Engine: Cammed 6.0L LSX
I've read on here that the 93-97 master cylinders are different from the 98-02 pieces. I bought a new aftermarket MC with reservoir about 2 years ago and never got around to installing it. I'm wanting to do it here soon but I read that the LS1 style (98-02) is the one to use because the threads should be the same, not sure of any other differences though.
Is there anyone that can tell me what I can look for on this new part to tell what style I have? Or maybe what size the holes would be for the 93-97 or 98-02? I want to use the right one, and I can sell this one if it's not the right one.
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Which 4th gen master cylinder do I have?
'93-'97 has the same threads as you currently have.
'98-'02 has different thread size and is more desirable to avoid a spongy type pedal. If you look in the master you will see 2 holes in the rear portion that will be for the Ls1 and if it has 1 hole that's for an Lt1 let me find the pics for you.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
So can you tell which one this is? Because I can't see much in the picture posted above, it's too small.
Car: '88 Trans Am
Engine: 5.7L TPI
The picture is from Google and that is the way it was shown but give me a minute or two and I will try for a new pic with both parts if available.
Thanks for your help! I would rather put an LS1 MC on the car, even if I have to cut the lines and put new fittings on...I want the best pedal feel.
Dang that stinks. I guess I'll be hitting up LS1tech for one and just swap out the brand new reservoir to the one I purchase. This thing is brand spanking new never been used. Only has fluid in it from the manufacturer to keep the seals good.
Axle/Gears: '01 3.42 10 bolt
as far as what you have for the thread sizes here, you have it backwards. the LS1 master has the same threads as the later 3rd gens.
I picked up a used LS1 master cylinder for $15 today, since I have the brand new LT1 MC with a new reservoir I'm going to swap that over so it looks nice and pretty. I'm sure I can sell a brand new LT1 MC for more than $15!
Car: 1998 grand cherokee, 1988 iroc z
Engine: 350 tpi
Axle/Gears: ???
so... if i was to swap out mt MC with an ls1 MC, my brakes would be less spongy? is this a bolt in type of thing?
Apparently. I can't wait to get mine on and bleed the brakes. My fluid has been contaminated for a while and I can't even lock them up anymore.
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
How did the ls1 mc work out for you?
I don't know, because I am not making enough vacuum to operate the brakes properly. My issue wasn't bad fluid or a bad MC after all. I've got 11 #'s in the system when it's running. The MC fits good though and looks great, guess I need a new booster or a vacuum pump or something.
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Did you ever figure out the problem? bout to go with a LT1/LS1 booster and a LS1 MC.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
