LS1 brake swap - braided lines
Old May 1, 2012 | 11:56 PM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
Axle/Gears: 4gen 3.23 PBR
Hi
I plan to swap my front brakes .I have all the parts to do ls1 swap except brake lines.Will this brake lines (check this link) set work for my swap.
http://flynbye.com/catalog/i204.html
I already have 4th gen rear with pbr's or I have to order separate brake lines for front and rear.
Thanks.
Old May 3, 2012 | 06:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LS1 brake swap - braided lines
ls1 rear brakes use longer hoses than the 3rd gen, so to use them properly, you need the proper 4th gen rear hoses.
Old May 3, 2012 | 08:32 PM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
Will front braided lines from this kit above(link) work for LS1 front brake swap. I already have 4th gen rear with pbr's and I will keep it. Only changing fronts.
Old May 4, 2012 | 09:38 PM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
Hi guys
I really need help to order right set for my setup( front ls1 and rear pbr).
Thanks.
Old May 5, 2012 | 02:43 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Originally Posted by CAMAROSKI
Hi guys
Thanks.
I need the same answer.
Old May 11, 2012 | 10:56 PM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
Well I called Flynbye and left massage but nobody called me.We all know how hard is to get him to contact us.So in this case i will order just hoses for front brakes unless somebody can (count on you) help.
thanks.
Old May 31, 2012 | 10:35 AM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
anybody have an answer for the question, as i need to order the brake hoses also?
thanks
Old May 31, 2012 | 10:58 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Ask http://bigbrakeupgrade.com/contact.html He has always responded in the same day.
I asked about reusing the braided hoses I currently have on my stock brakes & his response was:
"The hardline side of your hoses are 10mmx1.0 female bubble flare and the caliper side should be a banjo 10mm....the actual bolt that goes into the caliper thru the banjo is a 10mmx1.5. Your hoses would cross over to the C5 kit, the banjo bolts are a different thread (10mmx 1.0) but are supplied with the kit. The hoses you have are going to be too short to use on a LS1 kit."
I also about about LS1 vs C5 upgrades:
" A lot of the decision is usually dependent on the wheels on the car, but if your an open ticket I would suggest the C5 for a few reasons...
  • Pressure cast calipers vs. the LS1 gravity cast (less chance of caliper bridge spread)
  • Larger diameter rotors have more leverage vs smaller
  • C5 rotors are left and right specific with curved vents that advance the airflow through the rotor more effectively
  • Caliper clocking and abutment bolt spread allow the retention of the spindles stock steering stop
  • Many bolt on options for the base setup including all C5 variants and all C6 variants 12.75, 13.4, 14 inch rotors and 2- 6 piston calipers plus CTS-V brembo`s bolt on.
The LS1 has it`s advantages as well..
  • Fits under a typical 16 inch wheel
  • Larger width rotor than other stock type 16 inch rim capable upgrades
  • Expense to performance ratio
  • Bolt on options of 2010+ Camaro brake parts (with minor modifications and wheel size increase)
Both base kits as you can see can be up-fitted if needed and both offer advantages the other cannot. I would be happy to help you with which ever you choose."
Old May 31, 2012 | 12:03 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
that helps. so in order to use the ls1 calipers, i would need actual ls1 hoses? will those work with the stock hard lines?
Frozer!!!
Jan 19, 2024 04:55 PM
NBrehm
Aug 25, 2015 11:49 PM
sreZ28
Aug 14, 2015 07:48 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
