LS1 Brakes Installed on my 89 Formula *PICS*
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
I just installed the ls1 front brakes on my 89 formula, it cost me around $500 total. I was able to use my stock brake lines/rubber hoses, the worst parts of this install were getting the spindle off the ball joint, and needing a front end alignment really badly after, other wise, i got my parts for the conversion from Bigbrakeupgrade.com and i give them an A++ they have a very useful website and fast responses + shipping. Here are some pictures of the swap below.
And is anyone is curious I weighed each spindle setup,
STOCK weighs 41 LBS
LS1 weighs 49 LBS
overall review..i have only been driving them for a few hours today braking them in and they have SOO much more grip than the stock setup, and its nice to see big rotors behind your rims, great upgrade recommended for any 3rd gen.
STOCK weighs 41 LBS
LS1 weighs 49 LBS
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Re: LS1 Brakes Installed on my 89 Formula *PICS*
Very Nice. Two questions for you - did you need an alignment b/c the new spindle has different dimensions than the old? And what approach did you take to bleeding the brakes? Thx!
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
I too did the LS1 brake conversion, its a great mod for the price.
No alignment needed, the same hub is used after machining and everything should go back together just like it came apart.
Bleeding the brakes, well...I've got to take my master cylinder off and bench bleed, then re-bleed the entire system. I've got a spongy pedal feel that I can't seem to get rid of no matter how much I try. Since I emptied all the lines, I assume a bench bleed of the master will cure my problem.
And the rest of the bleed - used a pump or two person job? I'm trying to figure out the simplest (cheapest) way to change the brake fluid.
Car: 1992 Camaro Z28 Z03 Vert
Engine: 5.7L Vortec TPI
Axle/Gears: 3.23 Posi
I agree. Earl's Speed Bleeders worked great when it came time to bleed the brakes on my LS1 brake conversion.
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Did you cut the spindles yourself or buy the modified ones from Bigbrake?
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
gravity bleed, and then watch paint dry. just kidding. using a second person to put pressure on the system, I found is the best way. or if need take a bottle and put about 2" of brake fluid in the bottom. Then drill a hole in the cap and put a clear hose into it and down into the fluid. Next attach it to the bleeder and pump the brakes. do it slowly and check frequently. you do not want the hose to come out of the fluid
I cut the spindles myself with a grinder, very straight forward just follow the cutting diagram...very simple task anyone can do it. Bleeding the brakes was a 2 man job, i had my brother pumping the pedal and holding it while i released the pressure from the bleeder. REMEMBER do not mix up the left and right side calipers!!!! the bleeder should be on the top of the caliper, not on the bottom, i did that and never got all the air out of my calipers, and yes i think i need to bleed my master too because my pedal can go down 1/4 of the way without doing much, but then after than this thing stops real good
** also i forgot to add, my alignment was wayyyy off on the drivers side for some reason, maybe the spindle i got from the junk car was tweaked but the car had no signs of damage...the guy at the alignment shop said the right side dropped right into alignment but the left side was wayy out there, but all is good now
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Nice swap!
Hey on my LS1 brake swap, I noticed that the rotor has a little play in it...I mean it can turn a little bit like 2mm back and forth, once it is on the hub.
It will turn and hit the studs then will turn back and hit the studs.
Is this normal??
Is this normal??
yeah its normal, and once the wheel is bolted up it should eliminate the play
Car: 1995 Formula
Engine: LT1 350
sailtexas186548
Jan 19, 2016 12:21 PM
