Drum To Disc E. BREAK
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
I have what I assumed were the correct e break cables...they seem to be too long or they need to be routed a particular way?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Drum To Disc E. BREAK
are these the pbr calipers ? There are two different length tunnel-mounted adjuster, is 1434 mm. The second design is 1460 mm. This longer cable was designed for cars with no adjustment
https://www.thirdgen.org/forums/engi...sc-ebrake.html
