Brake Kit Comparison, Pedal Travel and Pedal Effort, and specification.
Old Jul 11, 2012 | 02:24 AM
87350IROC's Avatar
Car: 87' IROC
Here is a table of common brake swaps and how they effect brake pedal effort and travel. The two most important aspects of brake feel.
There are tons of threads on here for people looking for recommendations. Hopefully this will add a little science to the usual list of biased recommendations.
Perhaps we can make this a sticky and add to it for future reference.
The numbers assume the following for all kits listed
- same caliper flex
- same pad coefficient of friction
- same master cylinder bore diameter
- no losses in the hydraulic system
- no pressure lost moving sliding calipers
Right click - view image, for a larger image
Some other points to consider:
- Brake pedal travel and effort are feel items. Personally I like a short medium pressure pedal.
- The much vaunted 1LE setup actually produces much less brake torque than the stock 10.5" setup. Probably not a bad deal for the race cars where less assist is not such a bad trait.
- Big rotors are "free" brake efficiency, you can get the extra brake torque from a large rotor without the downside of a longer pedal
Finally, I would love to add data for more brake kits. Let me know if you have data for other kits or any of the missing data in the spreadsheet.
Old Aug 17, 2012 | 12:48 AM
87350IROC's Avatar
Car: 87' IROC
Re: Brake Kit Comparison, Pedal Travel and Pedal Effort, and specification.
Added a few kits.
Again, right click - view image for larger version.
Old Aug 23, 2012 | 12:26 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Old Oct 25, 2012 | 03:17 PM
92-Formula's Avatar
Great post! Wish I went with the CTSV brakes... although I can't complain about the LS1 setup I got. Although I wish there was less pedal travel.
Old Oct 25, 2012 | 04:13 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
This is very useful information, with the added benefit of pedal travel and effort...
The main reason why the 1LE front brakes were so sought after was the 1.5" increase in rotor diameter and the change from an iron single piston to an aluminum dual piston caliper. Effort aside, it was enough for the 3rd gens to race and not wipe out their brake in 3 laps...
Larger diameter rotors are becoming the norm, especially with tire sizes increasing the last few years (5th gen Camaro and Hemi cars for example). But the tires have not kept up pace in terms of using all that extra braking power - ABS is a savior for not locking up the wheels.
I have the old Baer 2 piston Track kit on my Camaro (same as the C4 HD above) and when I installed it, I tested it and it dragged the car from 60 to 0 in 105ft consistently - on a 245-50-16 tire. We are talking about a car with no ABS and smallish front street tires and it would rank up in very nice company in 2012 in terms of stopping ability. Would they eventually start fading in a high speed racing on a road course - maybe. Would the rotors warp in such a race - probably (easy to fix with a 2pc rotor). The CTS-V system as nice as it is - requires a 19" wheel to fit (maybe an 18" with a very large wheel barrel), which makes it a very expensive proposition on any car it did not come stock on - definitely overkill on anything other than a 6000lb SUV.
Personally I think the sweet spot for a third gen is a 13" rotor (1 or 2pc), a 4 piston stiff caliper (like the Wilwood FSL or Baer Track 4) and a 275-40-17 tire.
Old Oct 25, 2012 | 09:37 PM
Nelz's Avatar
I would have said the SSBC 4 piston caliper with 12 inch rotors as one of the best but then you need Corvette rims as the caliper is wider. The SSBC quick change caliper basically is a 1LE caliper for the 10.5" brakes with similar piston force. Therefore the stock calipers in my opinion were better than th SSBC quick change calipers. If you're going to spend $300 on calipers you could go to LS1's from the boneyard if you lived in the US. Canada everything is more expensive so unfortunately it made more sense to upgrade the brake lines and rotors and prop valve and call it a day.
Old Oct 26, 2012 | 12:22 PM
87350IROC's Avatar
Car: 87' IROC
Again, you are going by the assumption that more piston force is better. Its really a question of feel. I can't stand a long pedal.
On top of that you have other considerations, like thermal mass and heat rejection. The table merely points out the mechanical advantage and feel of the systems. It says nothing of how they would hold up on the track.
Old Oct 26, 2012 | 02:11 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
2pc w/6 piston for those track days! Agree that 13" rotor w/17" wheel a good sweet spot for weight, as well.
Old Oct 26, 2012 | 03:01 PM
87350IROC's Avatar
Car: 87' IROC
I have designed a kit around the big Wilwood W6A caliper on a C5 or C6 Z51 rotor. This kit would be awesome for a right sized track setup. It would sure look the part too. Only problem is the calipers are fairly expensive. I would love to build one of these though. I'm trying to get my hands on a caliper to play around with.
I will add a few kits to the chart and update one of these days.
John
Old Oct 26, 2012 | 06:56 PM
paul_huryk's Avatar
John
Very interesting...
Keep us posted!
Old Oct 26, 2012 | 07:12 PM
87350IROC's Avatar
Car: 87' IROC
Very interesting...
Keep us posted!
Yeah, it would be very cool. Its hard to justify spending $500 on a caliper just to confirm a fitment and take some pictures. But I have done crazier things before.
Old Oct 30, 2012 | 03:11 PM
Nelz's Avatar
Any mods out there? I second making this post/chart a sticky!
Old Apr 17, 2018 | 07:26 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Bump to top, 'cause it's so good!
Old Apr 17, 2018 | 10:27 PM
CCS84's Avatar
Car: 84 T/A
Great Little Sheet. What do you mean by the Pad Volume? And how did you calc torque? Did you assume a line pressure to arrive at piston force and thus torque based on rotor diameter?
I have Baer SS4+ kit which works well for me. Shame they don't do a rear kit that fits the 15" wheel too.
S4 caliper uses 1.755" pistons, weighs 5lbs with pads.
Rotor is a 11"x1.02" thick two piece. I'll check weights for you when I get to it but I'd guess-timate 12-15lbs
Charlie
1992 Trans Am
May 10, 2023 07:19 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
