Leaking brake lines
Old Jul 21, 2012 | 09:06 PM
bobby85z's Avatar
Car: 85 Camaro
Leaking brake lines
the person i bought my camaro from patched the rear brake line with a 6" pice of rubber hose and 2 hose clamps and are now leaking. whats the best way to repair this. or do i replace entire line?
Old Jul 21, 2012 | 09:09 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Leaking brake lines
replace the flex line and bleed out the brakes.
Old Jul 22, 2012 | 06:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO, bobby.
Just an FYI: The pass side caliper has flex line, the drivers’ side a hardline.
JamesC
Old Jul 22, 2012 | 06:59 AM
nhgator's Avatar
Car: 1985 T/A
When I bought my t/a it had new brake lines,unfortunately they were joined in places with compression fittings.
After my 2nd trip to the parts store trying to fix one area at a time I just bought enough to replace it all,wasn't terribley expensive and it's good piece of mind.
Old Jul 22, 2012 | 11:46 AM
bobby85z's Avatar
Car: 85 Camaro
JamesC
Thank you! it's the drivers side hardline. can it be patched? or do i have to replace the whole line?
Old Jul 22, 2012 | 12:06 PM
JamesC's Avatar
I'd think it would be more trouble to patch than replace. The following sites should have what you need:
http://www.finelinesinc.com/
http://www.classictube.com/
http://www.inlinetube.com/
JamesC
Old Jul 22, 2012 | 05:42 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I just finished my front brake hoses and found out something good. The gravity brake bleeding method works great. Hooked up the proper size hose to the bleeder valve and ran it into a coffee can. Opened the bleeder valve keeping an eye on the master cylinder to keep it topped off. It takes longer but no air in the system what so ever. This is just an F.Y.I.
Reddeath210
Oct 6, 2015 08:20 AM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
