Upgrading the brakes this week
Old Sep 12, 2012 | 10:21 AM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Upgrading the stock brakes that are metal on metal (apparently these pads didnt have squeal pads) to the summit xdrilled/slotted rotors, ceramic pads & all the wheel bearings...
The stock setup really sucked a$$ and I'm REALLY hoping that this new get up will help the stopping distance
Old Sep 12, 2012 | 07:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Upgrading the brakes this week
it will be worlds different that shot pads and metal on metal. YOu will see a much more noticeable eim[improvement with a brake upgrade with a larger caliper and rotor
Old Sep 13, 2012 | 12:15 AM
87350IROC's Avatar
Car: 87' IROC
Invest your money in quality pads, rotors, and bearings. Don't waste your money on drilled or slotted rotors. They are NOT going to improve your braking performance. Instead, if you really want an upgrade, save up for a replacement system.
Old Sep 14, 2012 | 07:38 AM
Car: 1988 Iroc-Z
I already have everthing put on and I couldn't wait another day to order everything, nor to piece an upgraded package together...
Just going with the stock drilled & slotted decreased my stopping distance by 1/2 of the original... Plus I think that my passenger side front caliper was stuck... Anyway, KILLER upgrade for using stock parts
Old Sep 14, 2012 | 09:27 AM
FryeDaddy's Avatar
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
I wanna do the same from drum brakes..idk where you getting the set at but I saw an whole set for 1200 from classic preform yet not sure it's for our third gen. Anyways I wanna get information about your upgrade experience :-)
Old Sep 14, 2012 | 09:40 AM
87350IROC's Avatar
Car: 87' IROC
Your stopping got better because you fixed a problem you had with your brakes (no friction material left). No because you got drilled and slotted rotors.
Old Sep 14, 2012 | 01:16 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
have to agree with 87350iroc lack of brake pad made a diffrence no the rotors drilled/slotted rotors help with cooling/venting of the rotor... metal to metal rubbing cant be good in anything unless your eating a steak lol
Old Sep 14, 2012 | 10:00 PM
Car: 1988 Iroc-Z
Lol I'm not retarded. I know braking will improve with any new equipment, with in reason, BUT from having stock style pads and rotors on it for the 1st 15000 miles I had the car compared to the new set up, there is a HUGE difference.
Frozer!!!
Jan 19, 2024 04:55 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
gta90
Sep 15, 2015 04:00 PM
zayne0
Aug 24, 2015 07:22 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
