Bad Luck (broken bolt)
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
I was installing my 1LE kit from Ed Miller today, and while I was torquing the caliper adapter bracket to spindle bolt to spec, the head snapped right off. Now I have no idea what to do. Has this happened to anyone before? I am beyond frustrated, and as of now have an inoperable car.
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Bad Luck (broken bolt)
Can you remove the bracket & use vicegrips or is it busted flush on the mount?
IDK- grasping at straws for an idea
Engine: 355 TPI
Dude, you are a huge effin' stud. In my frustration, I didn't think of the most simple solution. I owe you a beer.
Car: 87' IROC
Engine: 355 TPI
It was a 14mm head, I'm not sure what pitch it was. His instructions specified 75 ft lbs, which the bottom bolt did, but the top just sheered. I'm thinking it's because the top bolt bottoms out in the hole as opposed to the bottom one which has a hole on the other side.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Odd. None of mine were blind holes on Ed's kit.
Sometimes it just happens.
Better that it broke now, than right behind a school bus or something.
Definitely do check to make sure it's not bottomed though, so you don't (a) have it happen again, or (b) reach full torque before it's actually holding the pieces together.
Car: 87' IROC
Did you put any lubricant or thread lock on the bolt?
Definatley make sure the bolt isn't bottoming out.
Engine: 355 TPI
Even if the bolt DOES bottom out, which is just my theory so far, should grade 8 bolts handle 75 ft lbs of torque?
Car: '87 Camaro
Couple weeks ago I broke some fender bolts on " the other " car. I had to heat them a bit with a lil propane torch then did the vice grip thing. Worked out good-- home it goes ok for you-- good luck
Engine: 355 TPI
Yep, it worked like a charm!
Car: 92 T/A 'vert
Strange. The head marking on that bolt suggests its a grade 8 bolt which suggests it is SAE. So I don't see how its possible that it has a 14mm thread. Instead I suspect its a grad 8 7/16-20 bolt. That would normally have a torque spec of 75ft lbs dry.
IIRC, mine were a metric/Allen head capscrew. But, it was 2 years ago and I'm borderline senile.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I managed to bottom out a metric 10.9 bolt on my setup. Fortunately ace hardware had a replacement bolt I was able to use of the same size/grade. Had to laboriously drill it out with bigger and bigger drill bits until it crumbled. Avoid that at all costs, but if you have to drill it out you can. It will chew up the drill bits but as long as you dont force it, you will make slow, steady progress.
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
