looking for some adapter hubs...made from an S10
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Anybody know of anyone who makes adapter hubs from an S10? I'm looking for a set so I can integrate ABS. Certain mid '90's S10 front rotors use the same wheel bearings as thirdgens do plus they have a tone ring.
Has anybody on here done this? From what I see the rotors are the same minus the tone ring.
Car: 87' IROC
Re: looking for some adapter hubs...made from an S10
You should have no problem getting a local machine shop to do the work for you.
Ill do one better. Gonna go pick up some today if I get off work early enough. Rather not spend the extra cash on new pieces just to cut them up, but by the time I went to the boneyard and got used, I could have shiny new ones anyway.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I have a set of baer aluminumb s10 hubs with the abs rings if you are interested. I'l let5 them go cheap too
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Car: 87' IROC
Interested in those hubs. PM some info over to me.
The ABS swap won't be too hard. Im already in the process of swapping over to a complete 4thgen electrical system with my dash swap, so the hard part is already done for me other than running new lines. Car is gutted, making things that much easier. Ill be running factory bags, vats, and keyless entry too.
