ls1 Brake lines
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
ls1 Brake lines
Just wondering if anyone has tried these brake lines from Hawks
http://www.hawksthirdgenparts.com/pr...LE-Brakes.html
If so how did you like them or is some else selling similar setup for less??
Car: 87' IROC
Re: ls1 Brake lines
Car: 89 Formula 350
Re: ls1 Brake lines
I have my LS1 brakes ready to install. I got my calipers second hand and I think I might be missing some parts. I watched a Youtube video of a guy doing an LS1 brake install and he had some tin clips that went between the mounting bracket and the calipers, top and bottom. I don't have those. I'm guessing I can just buy them at an auto parts store..what are they called??? Thanks
Car: 87' IROC
Re: ls1 Brake lines
Car: 89 Formula 350
Car: 87' IROC
Re: ls1 Brake lines
Those are pad slider shims. They typically come in caliper hardware kits. You will need
Raybestos H5641A or similar.
Car: 89 Formula 350
Re: ls1 Brake lines
Thanks I got them today, I also got new stock for my car brake lines being I'm getting low on cash. I decided not to get the braided lines.... I do need to get those copper washers that go between the caliper and brake line. I was wondering if it would be better to go with the one for stock brakes or for LS1 brakes..Anyone have a part #?
Car: 87' IROC
Re: ls1 Brake lines
