9 bolt disc brakes?
Old Feb 17, 2013 | 01:13 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
9 bolt disc brakes?
Hey guys, I'm shopping for new brake parts (rotors and pads) for the 9 bolt rear end I picked up for my car. I'm shopping online for 88 firebird parts (mines a 91 but I was told my axle came off of an 88 G92 formula), and I'm just afraid to order the wrong parts. Is there a difference between 9 and 10 bolt disc brake components? The only note rock auto has on their website is whether they're 1LE parts or not.
Old Feb 17, 2013 | 01:31 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 9 bolt disc brakes?
The brackets are different. You need to know if it's 1Le or not. What diameter are the rotors and are the calipers both behind the axle or is one in front and the other behind? The code would be a guide but only looking is for sure.
Old Feb 17, 2013 | 01:40 PM
Engine: LB9
I'm pretty certain it's not a 1LE axle. And yeah I have one caliper facing the front and the other faces the back.
Old Feb 17, 2013 | 01:41 PM
Engine: LB9
I'm only trying to buy the pads and rotors anyway, calipers seem reusable.
Old Feb 17, 2013 | 02:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Based on what you've said, buy for an 82-88 and you'll be good to go.
JamesC
Old Feb 17, 2013 | 02:57 PM
Engine: LB9
JamesC
Works for me! But 89-92 rear discs were different?
Old Feb 17, 2013 | 03:05 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
The ones you've got are Delco Moraine "iron caliper" with 10.5" discs. The 1Le are aluminum calipers with 11.6" discs.
Old Feb 17, 2013 | 03:07 PM
JamesC's Avatar
Yes, the 89-92 J65 brakes, the so-called 1LE's (or performance package) were equipped with alum PBR calipers mounted on the back side and 11.7" rotors.
JamesC
Old Feb 17, 2013 | 03:26 PM
Engine: LB9
Ah I see, so seeing that I DON'T have aluminum calipers, there's no chance that my rear end is any newer than 1988 correct? Because I was told that 88 was that rear's approximate year when I bought it; the seller wasn't 100% sure.
Old Feb 17, 2013 | 06:23 PM
JamesC's Avatar
Correct.
JamesC
Old Feb 17, 2013 | 06:52 PM
Engine: LB9
Gotcha, well thanks for the help guys! Looks like Internet shopping spree time tonight haha!
Old Feb 17, 2013 | 07:34 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Here is a pic of my 9 bolt with 1LE PBR's
https://www.thirdgen.org/forums/albu...ictureid=24412
Old Feb 17, 2013 | 08:28 PM
Engine: LB9
Looks good!
Old Mar 18, 2013 | 03:02 PM
Zerofox's Avatar
Car: 1984 Camaro Sport Coupe
Engine: 350 SBC
Where did you get your conversion kit? Specifically the brackets. My 9 bolt has the funny looking front and rear cast iron calipers, and i want badly to do this while I have the rear out of the car already
Old Mar 18, 2013 | 03:33 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Flynbye.com is one place. Components or the whole kit. The kit is expensive but it's complete and shiny.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
overdriv
Aug 20, 2015 03:52 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
