caliper bad?
Old Feb 28, 2013 | 02:48 AM
iroczjoe's Avatar
Car: 1987 iroc z
Engine: 305 tpi for now
Axle/Gears: 3:24
caliper bad?
87 iroc disc brakes. resolved front brake problem, now have rear brake problem. previous owner improperly compressed rear caliper. i went and bought a caliper and put in on with new pads. started it up and pumped the brakes, piston never came out. i pumped it some more ( pumped the hell out of it) still didnt move. then i loosened the bleeder valve and no fluid cam out. i thought to my self "yup need a new hose,,,,but i was wrong. i loosened the brake hose and fluid went everywhere. so i guess my autozone caliper is junk.??????? or am i just dumb (not my first brake job) but starting to feel like it is.
(already posted in brake section)
Old Feb 28, 2013 | 08:36 PM
joshc's Avatar
Car: 1986 Trans Am
Re: caliper bad?
You didn't say you bled the caliper. Do you know how to bleed brakes?
Caliper won't have any fluid coming out the bleeder screw until you bleed it properly.
If you are not familiar with the process, let me know. I'll walk you through it.
Old Mar 1, 2013 | 09:28 PM
iroczjoe's Avatar
Car: 1987 iroc z
Axle/Gears: 3:24
Re: caliper bad?
i know how to bleed brakes. how can you bleed brakes if theres no fluid coming out of the bleeder valve.
Old Mar 1, 2013 | 09:35 PM
iroczjoe's Avatar
Car: 1987 iroc z
Axle/Gears: 3:24
Re: caliper bad?
ive done several caliper replacements and never had this problem.
Old Mar 1, 2013 | 09:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: caliper bad?
You have to bleed the air out before fluid will come out.
Old Mar 1, 2013 | 09:57 PM
iroczjoe's Avatar
Car: 1987 iroc z
Axle/Gears: 3:24
Re: caliper bad?
lol if the bleeder valve is completely out still no fluid is coming out. you can pump it for an hour then loosen the valve nothing comes out. you can then take it out completely out and pump it for another hour and no fluid cmes out?
Old Mar 3, 2013 | 07:58 AM
joshc's Avatar
Car: 1986 Trans Am
Re: caliper bad?
Bleeding brakes is a 2 person job, unless you have a vacuum bleeder.
You need a friend to push down the pedal and hold it down. You open the bleeder for a few seconds and then close it. Your friend can then let off the pedal.
Repeat this step 10 or 20 times and I bet you'll start getting fluid out the bleeder.
It works best with a piece of clear hose attached to the bleeder nipple so you can see the fluid coming out. If there is still air bubbles coming out the tube you need to keep bleeding.
Old Mar 3, 2013 | 08:10 AM
joshc's Avatar
Car: 1986 Trans Am
Re: caliper bad?
PS
Sometimes you can gravity bleed a system. You crack open the bleeder, and open the cap on the master cylinder. Gravity will slowly push the fluid through the lines and out the caliper. You do not touch the pedal at all when doing this. Make sure to keep the master cylinder reservoir full.
Just pumping the pedal with the bleeder open does absolutely no good. Pushing the pedal may push some air out, but when you release the pedal, it just pulls air back in.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
gta892000
Sep 16, 2015 12:40 AM
rb85TA
26
Sep 14, 2015 10:29 PM
rudolphschenker
Sep 4, 2015 02:41 AM
