PBR E-Brake hardware Replacement
Old Mar 6, 2013 | 06:43 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Ok, I'm getting ready to start the rear disc conversion on my Z-28 which involves changing to PBR setup. I have most everyting to do the swap and I have new hardware for the calipers, my questions is this, what's the trick to installing the spring for e-brake on the bracket? Also, I've read about the set screw that has gotten some people with adjustment but I see no set screw, maybe it is missing, I' not sure. It would sure help to see some pics of these two items so I have an idea what to do. I've never messed with rear discs brakes so this is new territory for me and I don't a manual to cover these brakes. I've read a lot of JamesC posts on doing this which has helped but these two things have me stumped. Thanks for the help.
Old Mar 6, 2013 | 07:11 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Re: PBR E-Brake hardware Replacement
Ok, I finally found the link that JamesC put in for just that procedure that EBMiller posted with pics, now all I have to do is give it a try.
Old Mar 6, 2013 | 08:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
In a pic that Ed Miller once posted, he's pointing at the screw.
JamesC
Old Mar 7, 2013 | 02:27 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Thanks for posting that up, all I have to do is wait and see if I need the shims for centering the rotor up when I mock it up. JamesC you are a big help.
Old Mar 7, 2013 | 03:19 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Well, just when you think you have it covered turns out I'm missing one of the little springs that hold tension on the piston. Probably been missing for some time, now I have to find one so I can continue.
Old Mar 7, 2013 | 04:49 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
JamesC
The spring I am looking for is the one pictured in the this posting. Thanks if someone can get me one so I can get started on my conversion.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
Warlocksirix
Sep 3, 2015 12:26 PM
NBrehm
Aug 5, 2015 07:57 PM
