no break lights!!!
Old Mar 26, 2013 | 10:23 AM
mack1985transam's Avatar
Car: 1985 trans am
Engine: 355 vortec built 4 bolt main
Transmission: 700r4 w/ shift kit b&m console mega
Axle/Gears: 3.08
no break lights!!!
Have a 1985 trans am. All my lights work except stopping lights. My turn signals work great, my hazards work great, and reverse lights as well. I replace all fuzes with good ones and break switch. I also checked wiring and grounds. I rebuilt the steering collumn about 3 months ago and put a new turn signal lever switch and multifunctional in as well. I didn't have any problems then..... what could it be guys I'm stumped..... I had one bulb go out about two weeks ago and a week later they all went out I've been having this problem for about a week
Old Mar 26, 2013 | 05:53 PM
Car: 1985 trans am
Axle/Gears: 3.08
Re: no break lights!!!
Come on guys any help is appreciated! !!!
Old Mar 26, 2013 | 06:05 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
I googled several sites for you.
Based on the same "no brake lights" complaint by other Camaro owners, it would appear that the wiring for Camaro brake lights goes through the steering column.
You recently worked on the steering column and/or the turn-signal wiring.
You need to go back in there and find the failed connection.
Trace/test the circuit from the pedal to the bulbs.
Somewhere along the way, you will discover the fault.
My strong suspicion is that you will find it in the steering column and/or the turn-signal switch.
Old Mar 26, 2013 | 06:50 PM
Car: 1985 trans am
Axle/Gears: 3.08
I don't believe so because I just put in a new turn signal switch and it has been working fine for awhile now. Also the turn signals and hazours work fine. So your saying just track the wires??
Old Mar 27, 2013 | 09:41 PM
Car: 1985 trans am
Axle/Gears: 3.08
God bless maverick I thought I'd let you know personally it got fixed it was a loose wiper switch harness some how it came loose. Sleep well tonight brother!!!
jaridjohn
Jul 8, 2024 03:49 PM
ktthecarguy
Jul 5, 2020 11:46 AM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
89fast5oh
Aug 24, 2015 08:14 AM
Omega
Aug 10, 2015 12:46 PM
