locking up.
Old Aug 14, 2013 | 03:35 PM
eviljay's Avatar
Car: 1989 Turbo Trans Am
locking up.
My front brakes are sticking when they get warm. Bad fluid???
Old Aug 14, 2013 | 04:41 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: locking up.
What do you mean...sticking? You'll have to give us more information than that. Otherwise, change the calipers, change the master, bleed the brakes and you should be good to go.
Old Aug 14, 2013 | 04:50 PM
eviljay's Avatar
Re: locking up.
Sorry. Last year the driver side front caliper locked up and was dragging. When I'd brake it would pull to that side. I replaced that caliper and things seemed fine. (Stopping streight) Last weekend was the first time I had it out and the pedal is hard and the brakes are sticking when they get hot and letting loose after they cool down.
Old Aug 14, 2013 | 07:58 PM
eviljay's Avatar
Re: locking up.
Just bleed all 4 and still doing it. Next step flush the system change lines and maybe the proportioning valve...
Old Aug 14, 2013 | 09:11 PM
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
Re: locking up.
I had the same problem with my 92 gta. I jacked up the front wheels and had someone press the brake. With there foot off the brake try to rotate the wheel. If the wheel doesn't turn crack the bleeder on the caliper. If the wheel turns freely it is probably the rubber line between the caliper and the metal line or the proportion valve. IF it doesn't turn it is probably the caliper.
TX-SleeperC5
Feb 24, 2016 01:34 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
scottmoyer
Sep 7, 2015 07:06 PM
lakeffect2
Sep 7, 2015 03:52 PM
