replaced everything and front still lock
Old Nov 5, 2013 | 12:13 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
ok ive replaced everything on my car front to back and the front. but they are still so tight i cant turn the hubs by hand without a wrench between the lugs. ive yet to bleed it but i dont think thats gona do anything. are the rotors sapposed to spin freely or only a fraction of a revolution? any help will be nice thank you.
Old Nov 5, 2013 | 11:51 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: replaced everything and front still lock
Check this out out at step 43 to make sure you put them on right. Good luck.
https://www.thirdgen.org/forums/brak...r-install.html
Old Nov 6, 2013 | 10:11 AM
mikey8494's Avatar
Axle/Gears: stock
the thing is if i use a c clamp on my calipers and push the pistons back in and then spin the rotors they spin very freely its the brake pads grabbing on heavily wheni pump the brakes then not retracting
Old Nov 6, 2013 | 02:02 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Why do you need to bleed the brakes? Did you open a brake line?
Old Nov 6, 2013 | 02:48 PM
OdieTurbo's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 3.4L V6
Transmission: T5 (NWC)
Axle/Gears: 3.42 Stock axle
Caliper pistons not retracting properly can be caused by corrosion built up on the pistons themselves. Pop the pistons out and check for corrosion. If there is some, replace the calipers (they're still pretty cheap).
Old Nov 6, 2013 | 08:21 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Did you clean and lube the pin bushings?
Old Nov 6, 2013 | 08:34 PM
mikey8494's Avatar
Axle/Gears: stock
ok heres the thing i gota bleed them cuz ive replaced the master cylinder (twice within 2 weeks) replaced both front calipers and front flex lines. replaced the rear cylinders and the rear flex line . and replaced the combo block. so the pins dont need to be lubed the calipers came with new guide pins.
Old Nov 6, 2013 | 08:35 PM
Joe Tag's Avatar
Starting a new thread asking the same question is only a step backwards. Did you go through the checklist I gave you this morning?
Old Nov 7, 2013 | 10:31 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I have read on other forums that deteriorated rubber brake lines can plug up and keep the pistons from retracting. Although I have yet to ever experience this myself.
With disc brakes there's nothing to mechanically retract the piston and there's always some drag. But locked up the way you describe is not normal.
Old Nov 8, 2013 | 02:29 AM
84Z28HO50's Avatar
Car: 1984 Camaro Z28 H.O 5.0
Engine: 5.0L
Pump the brakes up and test to see if locked, if so crack open the bleeder. does the rotor move freely? no=bad caliper. yes, close the bleeder, repump and crack the line above the front hose. free now? yes=good hose and caliper. keep opening the line back to the master until you find the restriction. look for kinked or pinched metal lines.
Old Nov 20, 2013 | 12:03 AM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
that is actually very smart. good tinking there. i'll have to remember that if i ever have this brake issue on any vehicle in the future
Old Nov 20, 2013 | 11:51 AM
mikey8494's Avatar
Axle/Gears: stock
i got it working once i bled it it all worked out fine now i just gota get her insured inspected and tagged
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
