Rear brake drum to disc conversion
Car: 1987 Z28
Engine: 370hp 350
Transmission: 5 speed
Axle/Gears: G92 3:45 Posi
I'm looking to convert my 87 Z28 5 speed rear brakes from drum to disc. I don't want to change the rear axle so the question I have can you get a conversion kit for it or should I look for another rear axle already with disc brakes on it to swap the parts? How difficult is this going to be and has anyone done this before?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear brake drum to disc conversion
The drum to disc conversion has been done many times. Perhaps the easiest way is the following from Ed Miller:
http://www.flynbye.com/catalog/i182.html
or
https://www.thirdgen.org/ls1reardisc
Perhaps some general help:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Concerning master cylinders, combination valves, and parking brake cables:
https://www.thirdgen.org/forums/tran...-10-bolts.html
Since most questions have been asked and answered many times, I search is generally a good idea.
Best of luck with your projects,
JamesC
or
JamesC
Car: 1983 Z28
Engine: 385 Fastburn
Honestly swapping the axle out for a 9-bolt with discs isn't all that complicated, I'm happy with mine. Plus if you have some work to do with/in the gas tank it gives a good opportunity.
Car: 1987 Z28
Engine: 370hp 350
Ya I'm thinking the axle swap might be the way to go considering I'm going to replace rear suspension also.
Car: 1987 Z28
Engine: 370hp 350
When you swapped the rear axle did you have to change the offset on the rear rims?
Car: 1983 Z28
What I put in it was a 9-bolt Borg-Warner out of a slightly newer IROC. My back wheels are 15x8's and the fronts are 15x4's, so I have different backspacing and everything to begin with (lol). I'm pretty sure though that the IROCs had a different offset for the back though, there's probably a thread on here somewhere that would give you that info. Sorry I can't be of more help than that, I didn't run into those problems because of my wheel/tire choice, haha.
Car: 1983 Z28
However, a cool little bonus is that the same brake pads go on the 9-bolt as are what are on the front end of my car, makes brake jobs pretty simple.
Car: 1985 Iroc Z-28
I had an 87 axle in my Camaro, and recently purchased a 96 or 97 axle. I didn't want to be that wide, so I swapped the PBR brakes from the donor axle over to my third gen axle. Here is my experience:
https://www.thirdgen.org/forums/brak...pbr-brake.html
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
concider if you might want to go to corvette or forth gen wheels later on.if so the best thing to do is swap in a 93-02 rear.thats what i did.btw the 1998-2002 rears have the best brakes.
Car: 1985 Iroc Z-28
Good Point. I dig the IROC wheels, and am sticking with them personally. That is why I wanted to stick with the third gen rear end. I have kept the 4th gen axle though,and will toss it behind everything in the shed. It is in great shape. If I choose to go to different wheels in the future, it will be an easy swap back over to that diff.
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
