Sleeves for 2010 rotors on stock lug pattern?
Old Nov 17, 2013 | 01:23 AM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Im a dufus and completely scrrewed up the conversion from sae to metric. note to self.. check conversion before posting..
Old Nov 17, 2013 | 11:53 AM
87350IROC's Avatar
Car: 87' IROC
Re: Sleeves for 2010 rotors on stock lug pattern?
Originally Posted by RaverRacerX
i would like to not kill my wheel stubs. what is everyone doing?
What make and model 2010 are you talking about?
Can you provide more detail on what you are trying to figure out? Sleeves?
If you are referring to 5th gen SS rotors, you need to bore out the center bore then they slide right on. The wheel stud holes are large enough to allow for the different wheel bolt pattern.
Old Nov 17, 2013 | 03:58 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
yes the 5th gen rotors.
they are machined. what im talking about is the 3mm difference in the patterns. it looks like the rotors will move around a lot (more than on a stock brake set like the 4th gens). i want to find something that will keep them from doing that and possibly chewing up the studs and the hub. im a little worried itll create a sawing motion of sorts.
Old Nov 17, 2013 | 04:14 PM
87350IROC's Avatar
Car: 87' IROC
Once you torque the wheel down, the rotor cannot move. The friction created by the lug nut preload is what holds the joint together, not the fit of the drilled holes in the rotor hat.
If you insist, you can do as some OEMs do for production facility. You can drill and countersink a hole in the hat in between lug holes. Drill and tap a corresponding hole in your hub then run a countersunk screw to hold the two together.
You can see there is such a hole drilled in factory gen II CTS-V wheels. In fact I just checked my rotor stash here and there is already a hole in the factory 5th gen SS rotors as well.
1992 Trans Am
May 10, 2023 07:19 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
z28_AJ
Aug 27, 2015 08:59 PM
sreZ28
Aug 14, 2015 07:48 PM
