Double flare brake lines on a 4th gen rear??
Old Jan 17, 2014 | 10:41 AM
Elvis'92Bird's Avatar
Can I use a standard double flare brake line on a fourth gen rear and third gen "T"? And does a 1992 firebird and a 1995 z28 share same brake line fitting size?
Please answer, I need to fix my issue today.
Thanks.
Old Jan 17, 2014 | 05:14 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Re: Double flare brake lines on a 4th gen rear??
Hi,
My 3rd Gen IROCZ has Metric Bubble Flairs.
The Brake Line over the rear-end is 3/16". Not sure about the other runs?
Best Regards,
Bruce
Old Jan 17, 2014 | 05:48 PM
Twin_Turbo's Avatar
Actually it's a metric size, 5mm
Old Jan 17, 2014 | 06:01 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Hi,
I measured the actual line on the rear end. In multiple spots the measurements were much closer to 3/16 then 5mm.
There is always some error on the measurements.
Best Regards,
Bruce
Old Jan 17, 2014 | 06:35 PM
Twin_Turbo's Avatar
I have made a few of these lines myself and the flare nuts I buy here are for 5mm line, that's what matters..the inner size of the flare nut. the bubble flare will seal fine.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
