ebrake not working
Old Jun 28, 2014 | 01:18 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
ebrake not working
Barely passed inspection without a parking brake. Just bought it. There is no resistance when I pull on the handle. Just goes straight up. Is this a snapped cable?
Old Jun 28, 2014 | 01:48 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: ebrake not working
Update your profile with more info about your vehicle. Check your rear brakes. Could be worn discs/pads or out of tolerance rotors/drums as well. Get the rear end up and see what the brakes do when you pull the hand brake.
Old Jun 28, 2014 | 01:51 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Im sorry about that its an 86 trans am 305 tpi. When I pull the e brake with the car lifted I don't notice anything happening by the brakes in the back
Old Jun 28, 2014 | 02:14 PM
antares57's Avatar
Use the diagrams attached and see if you can find a disconnection somewhere. Should be all mechanical. Good luck,
Attached Thumbnails ebrake not working-parkingbrake_a.jpg   ebrake not working-parkingbrake_1a.jpg
Old Jul 7, 2014 | 06:04 PM
MissChevySS's Avatar
So... went to pull my ebrake during parking the other day and pretty much heard the cable snap... from the first look, it looks like the cable snapped at the lever, my question is, how do i know exactly if its the front, or rear R or L? and is there a special procedure on the replacement? i have drums in the back... 88 iroc
Old Jul 11, 2014 | 03:55 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
The parking brake is just the REAR, no vehicle has and parking brake mechanism on the front axle. You have to pull it apart to see if its the left or right cable
Old Jul 18, 2014 | 10:30 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The e brake is a fairly simple mechanism. The handle connects to a single cable that has a flat bar 1/4 thick by 1/2 wide by 6" long. The cables that connect to the calipers connect here, it's above the drive shaft. If the cables are good it could be the tension mechanism inside the car attached to the handle. There is a spring that keeps tension on it. If the spring is broken or disconnect then there would be no tension.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
