Will rear disc brakes off 85 TA work on 89 TA?
Car: 1989 Trans Am
Engine: 5.0L V8
Hey guys i have an 89 Trans Am with rear drum brakes that i want to get swapped out to disc brakes. I have a 85 Trans Am that i want to remove the rear disc brakes from and install into the 89. Wanted to know if anyone knows if the 85 set up will work with the 89? Please and thanks in advance!
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Will rear disc brakes off 85 TA work on 89 TA?
Yes but you need adapter brackets and changes to the e-brake cables. Go to the brake board and do some searches there. You should find all the info. you need. And make sure you know if you're dealing with 9 or 10 bolt and which disk brakes. There are two different models. Yours should be the iron ones with one caliper in front and one behind the disk. There are some issues with those which you can read about. Post pics if you can.
Car: 1989 Trans Am
Engine: 5.0L V8
Im almost positive its a 9 bolt with the iron disc brakes. Will post pics in a few hours when i get home to confirm. Assuming i remember right and it is that set up what would you recommend as far as the brake conversion goes?
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
If you've got them and they work then go ahead and do the swap. However, most people recommend going to the later model PBR aluminum caliper brakes. They are much better but cost more as they are desired and the iron ones aren't. I found a deal (<$100) on a complete PBR set up and swapped out the iron ones. Depends on what you can find. You still need some conversion stuff.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Essentially a bracket to mount on the axle flange that the caliper carrier bolts to. Redo the brake lines and redo the e-brake cables. Check the FAQs on the brake board and there are instructions and pictures somewhere.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Good luck. I bought a parts car ('86 TA) for the 9-bolt posi with iron brakes. I rebuilt the posi, swapped the brakes to PBR, redid the lines and swapped out the e-brake system. It took a long time and a lot of reading but it was interesting and it all works perfectly. I'm really happy with it especially as it's the first and only time I've worked on a rear end. I've got a built 10-bolt posi with drums so I'm getting ready to do the drum to disk swap now. You can get the brackets (and other stuff) you need from flynbye.com (amongst others).
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
