13.4/Z51 with 17s.
Old Jan 27, 2015 | 09:07 PM
Mr.ChevyStroker's Avatar
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
13.4/Z51 with 17s.
I literally just picked up some C5/C6 calipers with the z51 abutment brackets which means it uses 13.4 rotors. Dows anyone have any pictures showing where they hit on a 17inch Y2K's. Heres the calipers. How much would need to be grounded down if any at all. I can also use my 2 Inch adapters still correct?
Attached Thumbnails 13.4/Z51 with 17s.-20150127_180306.jpg   13.4/Z51 with 17s.-20150127_180317.jpg
Old Jan 28, 2015 | 12:15 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
Re: 13.4/Z51 with 17s.
I'be been looking at that kit on big brake upgrade and I think they said you need an 18" wheel for those, have to double check
Old Jan 28, 2015 | 12:17 PM
Car: RS Camaro
I saw that too, but I was reading where someone fit them under wagon wheels but it was close...
Old Jan 28, 2015 | 09:23 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
CTW Motorsports wheels fit the 13.4" kit with plenty of clearance.
Old Jan 28, 2015 | 09:34 PM
Car: RS Camaro
That's a 17 correct?
Old Jan 29, 2015 | 06:00 PM
paul_huryk's Avatar
Yes it is.
Here's a shot with the C6 Z06 14" kit...
Old Jan 30, 2015 | 08:43 PM
Car: RS Camaro
Sweet. I'm gonna cram the Z51 kit under the front wheels. Just gonna have to do some trimming of the calipers to be safe
Old Feb 3, 2015 | 05:46 PM
87350IROC's Avatar
Car: 87' IROC
Not all 17's have the same clearance. Measure first.
Old Feb 3, 2015 | 06:02 PM
Car: RS Camaro
From what I have measured and talking about with the big brake man is that it will fit but for clearance and safety he said I should grind down the tops a little just incase of anything now this doesn't mean they will clear all 17 inch wheels. Some are closer than others, the c5 zr1s will clear the spokes with a 1/4-5/16 spacer
simz28
Wheels and Tires
Oct 15, 2014 11:52 AM
Carlos773
Wheels and Tires
Apr 1, 2012 10:45 AM
Carlos773
Exterior Parts for Sale
Dec 17, 2010 10:37 PM
camaro05
Feb 3, 2004 07:39 AM
