Gravity bleed vs pumping and bleeding one by on Brembo
Old Apr 15, 2015 | 11:31 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
I initially did single man pump and bleed and pedal was still spongy to me do don't have that same feeling compared to Cadillac ATS with same setup
Did Gravity bleed firmness of pedal improved but not to my liking yet
I notice very very small bubbles still coming but no large ones let it bleed for like 8 mins or so still had very very small bubbles so I called it a day
I plan on doing 2 man bleed again see if that improve more
Camaro ss brembo up front
Ss rotors
Stock pbr rear setup
Braided lines front and rear
When I did single man bleed
I did passenger rear
Driver rear
Passenger front inner
Passenger front outer
Driver inner
Driver outer
And recommendations on firming pedal
Old Apr 16, 2015 | 07:39 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Re: Gravity bleed vs pumping and bleeding one by on Brembo
Your setup is a bit different than mine, Ls1 front, stock discs rear. Anytime I open the system at the master or prop valve it seems to take more to get all the air out. The master can be difficult. I think a combination of pumping and gravity will help. And it sounds like you have 4+ piston calipers since you are referencing inners and outers so that may compound the problem. There is always the possibility when changing to non-factory (for that vehicle) calipers that the bleeder port isn't at the very top of the caliper. Probably not an issue but something to check. A V-8 Vega I had one time had 2 left calipers so I had to remove the right side and turn it upside down to bleed it lol. Anyway, the pads contacting the rotors can leave some sponginess in the pedal until they are well seated. My pedal is pretty firm once it hits the friction point but can still be mashed further as in a panic stop. I don't know you will get it brick hard but it shouldn't be vague either.
Old Apr 16, 2015 | 07:54 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I'd try it with a friend. The single-man set up is good in a pinch but in my experience having help works better.
I've also had cases where it took WAY more tries than expected to bleed a system.
Old Apr 16, 2015 | 09:27 AM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
I had a problem with mine to so here's what I did I bleed the master on the bench an then started in the back ps side rear ds rear ps front ds front an backs were good the fronts nothing so this is what I did to get a good pedal I disc. the lines on the master an bleed it again on the car then I got every bubble out so next pump the pedal an do the backs if they are good go to fronts an pump the pedal not all the way down about 1/2 way an hold it you wont have any bubbles an you will have a good pedal you can also gravity feed them I did that to an got the same good pedal but this takes longer to do these are manual brakes dics to disc I hope this all helps.
Old Apr 16, 2015 | 10:28 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Caliper are installed right lol but it is honest
I'm bleed again see what happens my hanks for the info
Old Apr 16, 2015 | 02:08 PM
Car: 89 IROC
Engine: 6.8 HSR N2O
Bench bleed the master whenever possible. They are difficult to get all the air out of probably because of the angle they are mounted. Bubbles have a hard time going down hill.
Old Apr 16, 2015 | 06:34 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea I will try to do that I'm running 4th gen master cylinder its a brand new from dealer
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
backtothe80s
Sep 5, 2015 12:39 AM
RyanJB
Sep 2, 2015 01:27 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
