Question about clips on brake pads...
Old Nov 1, 2015 | 07:43 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
Do I need to use those clips? Because on my new pads they came with the clip attached to the center of the pad facing the piston, but the pads I took off didn't have them, so I took them off the new pads before installing them. Are they necessary? If so I'll search my garage floor for them and put them on.
Attached Thumbnails Question about clips on brake pads...-anti_rattle_clip_2_3f72cdce42f05adeb731f2e1161c46024b5a1572.jpg
Old Nov 1, 2015 | 10:29 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: Question about clips on brake pads...
You need them
Old Nov 2, 2015 | 07:34 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Originally Posted by mjdavis68
You need them
Yup.
Old Nov 2, 2015 | 07:39 AM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
I think I threw them out, can't find them. What are they for exactly? Just to stop rattling/noise? Or to help hold them in place / safety issue? And do auto parts stores sell the clips?
Old Nov 2, 2015 | 07:40 AM
Yes you should use them.
That kind of brakes can be REAL noisy without them.
Note also, that the other (outboard) pad, can also make lots of noise; they give you all sorts of goo, pads, this that and the other to stop it, but it often doesn't work. Best thing to do is to simply set them on edge on the ground and tap the little "ears" with a hammer to bend them inward, so the pad grips the caliper.
No idea whether you can buy just the clips without also buying pads. Never seen em sold that way but you know how that is.
Old Nov 2, 2015 | 07:41 AM
Car: 1983 Z28
They help to hold them in place. probably, or take them from a junkyard.
Old Nov 2, 2015 | 07:51 AM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
Damm, I'll look again when I get home. Bad thing is today is trash day so if I did throw them out then they'll be gone by the time I'll get home.
Old Nov 2, 2015 | 08:29 AM
-srs-'s Avatar
Car: 1991 Z28 Vert
Yeah, they will rattle like a son of a gun if you don't put them in. They're available at your local parts store for a few bucks if you can't find them.
Necron
Nov 7, 2015 07:12 AM
85@IRocZ
Nov 6, 2015 09:08 PM
noboostnogo
Nov 3, 2015 11:44 AM
789roby789
Exterior Parts for Sale
Nov 1, 2015 04:21 PM
hotrodln
Brakes
17
Oct 31, 2015 07:31 PM
