Thicker wheel stud question
Old Nov 8, 2015 | 09:51 PM
SsBenj's Avatar
Car: 1989 Iroc-Z
Transmission: Tick Stage 2 T56
Axle/Gears: 2.77
I just finished the 4thgen front brake conversion and while I was test driving the car I felt a wobble. Pulled over to check and noticed 3 out of the 5 studs had broken off. The hub had the Dorman 610-323 which are 12mm studs. I was wondering if anyone has ran 14mm studs without cracking the hub. If so do you guys have a part number?
Thanks,
Ben
Old Nov 8, 2015 | 10:35 PM
SsBenj's Avatar
Car: 1989 Iroc-Z
Axle/Gears: 2.77
Re: Thicker wheel stud question
I have used the search feature and nothing comes out about the front wheel hubs. I've read about the rears but I'm not sure if it's the same thing.
Old Nov 9, 2015 | 09:04 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
12 mm is stock size and work fine. Why the studs broke seems to be the issue. What hub was used? Is it fitting inside the stock wheel allthe way?
Were lugnuts all the way on tight and seated? Thicker studs arent going to solve the issue. The 12 mm stuff shouldnt break
Old Nov 9, 2015 | 11:54 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Yeah, you have problems somewhere. Find what wrong and then the lugs will be fine
Old Nov 10, 2015 | 09:43 AM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Tighten the wheel with open-ended lug nuts to see if your studs are too long for the closed-end lug nuts...?
Check the thread count above the nuts.
Old Nov 10, 2015 | 02:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Is it possibly you forgot to tighten them?
did you buy the hubs assembled or did you do them yourself?
who put the studs in?
Old Nov 10, 2015 | 10:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I have 7/16" studs on my front wheels. Roughly the same as 12mm. Don't need anything larger on the front unless you're driving a truck. On the rear, I run 5/8" studs.
I agree with the above posts. Use an open ended nut so that you know there are enough threads in the nut and they're not bottoming out on the stud before the wheel is tight enough.
It's hard to tell but those rims also look like they require a shank nut and not a tapered cone nut. If they are a cone style nut, I don't think the studs are long enough. The threads of the stud should be long enough to go past the surface of the rim by the diameter of the stud.
12mm stud should extend at least 12mm out of the rim for proper thread contact and holding strength.
Old Nov 11, 2015 | 12:49 AM
SsBenj's Avatar
Car: 1989 Iroc-Z
Axle/Gears: 2.77
I pulled the brake discs, took out all the studs and pressed the new ones on, carefully checked the hub that it sat flush with the rotor and put the wheels back on. I've driven it prob 45 miles on the street so far and I've checked the stud nuts(bought open ended ones from autozone for $2 each) and so far none of them seem loose. I've purposely driven on a bumpy road and pulled over to check them and they are still tight. I've came to the conclusion that the stud nuts might have been loose or not tightened all the way.
Old Nov 11, 2015 | 12:54 AM
SsBenj's Avatar
Car: 1989 Iroc-Z
Axle/Gears: 2.77
I did order the Arp-100-7708 with a .509 knurl the ones that are currently in there have a .504 knurl. Will the arp studs crack my hub of i try to press them in?
Old Nov 11, 2015 | 11:57 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Should be ok as .509 is stock asaik.
just line up the splines with the old groves on the hub when you press them in
Night rider327
Apr 19, 2016 08:59 PM
Night rider327
Exterior Parts for Sale
31
Apr 7, 2016 11:55 AM
Night rider327
Nov 9, 2015 11:26 PM
willyjoejr
Oct 19, 2015 05:31 PM
Silver87JC
Oct 19, 2015 01:28 PM
