Metric - Adjustable Proportioning Valve and Distribution Block ???
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Hi,
I nought a Jegs Adjustable Proportioning Valve and Distribution Block for my 1988 IROC
http://www.jegs.com/p/JEGS-Performan...62853/10002/-1
Problem is my car has metric threads that are a lot different to the SAE threads on the JEGS unit.
Is there a similar unit that I can buy elsewhere which will be closer in fit to my unit?
Or do others just buy brake line adapter fittings?
Also, the brake warning light sender is different on the Jegs unit, can I swap them over or do others rewire them for the new sender?
Car: 85 Firebird C&C T-Top
Engine: 347ci LS1
Transmission: 4L60E LS1
Axle/Gears: BW 9 Bolt Posi,3.27,C5+VE Brakes
Re: Metric - Adjustable Proportioning Valve and Distribution Block ???
Why don't you just remake the lines from the master to the jegs valve with metric on one end and sae on the other provided the pipe is close enough to flare either size.
The sender is just a 2 wire sender, nothing special about it just rewire to it.
Transmission: T700
Wish someone would make a combination block for metric, not just old SAE cars.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Never seen one
Engine: 347ci LS1
I've since gone for a master that puts the lines on the engine side of the car, rather than the outside. So much easier for clearance and access.
Transmission: T700
I've thought about that, but want to keep the (new) original Master Cylinder because it has a 1" bore.
I did get a 1998 Camaro Brake Booster, which is almost 2" slimmer. I hope this will move the MC closer to the firewall and away from the strut tower.
In hindsight I should have bought a Willwood MC that has exits on both sides rather than a new AC Delco unit.
I thought about a Commodore MC, but the problem is that Holdens use PBR brake parts, but the Camaros use AC Delco and the MC/Booster/Frirewall bolt spacing is different.
Engine: 347ci LS1
There is plenty of master cylinders available in all different bore sizes, including 1".
However the slimmer 4th gen booster should do it, again if i recall the rearward movement of changing that booster would give you the clearance you need.
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Just go out and buy some brake line adapter fittings, they come in standard to metric or metric to standard.
http://www.oreillyauto.com/site/c/se...aro&vi=5231704
88 vert guy
Apr 4, 2016 11:01 AM
