lt1 master cylinder with my setup?
Old Mar 12, 2017 | 02:28 PM
BuiltZ28's Avatar
Car has ls1 brakes at all 4 corners. I want to use the lt1 master, I like the looks of it better than the ls1 master. Any problems with this other than fittings?
Old Mar 12, 2017 | 07:22 PM
BBU.COM's Avatar
Top Answer: 1
Re: lt1 master cylinder with my setup?
I thought the fittings were the same? 12x1 mm and 11x1.5. My thought is your pedal stroke will become longer after the swap. you should have a 32mm/24mm dual stage master stock, going to the LT1 straight bore of 1 inch will require more stroke to fill and pressurize theoretically.
Old Mar 13, 2017 | 07:06 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I've had both 3rd gen and 4th gen LS1 master cylinders. The feel is indistinguishable. Yes, the stock master cylinder has a 32 mm step in the bore, but the majority of the bore is still same as rear brakes (24 mm or 25 mm, whatever the number may be).
Old Mar 13, 2017 | 04:03 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Other then the fittings not matching it will work. It will likely have a better feel then the stock quick take-up design. Then only other down side is that with the larger bore you will need to use more pedal pressure for the same stopping rate.
RBob.
Old Mar 13, 2017 | 07:06 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I thought if anything that the 3rd gen master is slightly larger bore. 1" (25.4 mm) plus the step, versus a 24 mm bore of the 4th gen style.
Again, my non-professional foot could not tell the difference.
Old Mar 13, 2017 | 10:56 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The LT1 & LS1 M/C have a 1" bore (25.4 mm). The 3rd gen M/C bore apparently varied between 25.4mm and 24mm over the years. With the 24mm bore being used more often.
When I upgraded the front brakes the smaller caliper piston area reduced the front braking by 28%. However, the larger diameter rotors and pads with a higher friction rating made up for it. Same can occur when a larger diameter M/C is installed at the same time larger rotors and better pads are used.
RBob.
Old Mar 13, 2017 | 11:40 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Yes, it is a given that different brakes can produce a different brake pedal feel. That is neither here nor there for the OP.
Old Mar 19, 2017 | 07:26 AM
BuiltZ28's Avatar
another question, I think I am going to be replacing the booster while I'm in there. should i use the lt1 complete booster/mc setup or stick with 3rdgen booster. something about the rod or something i remember being different
Old Mar 19, 2017 | 10:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This thread has a ton of LS1 & LT1 brake booster & M/C information:
https://www.thirdgen.org/forums/brak...r-mc-help.html
RBob.
