rear disc brakes on 84 Z/28
Have an 84 z/28 with rear drum brakes just purchased complete rear disc setup off an 2002 SS I have backing plates calipers rotors and hand brake cables is there any thing else I would need to fit this to my car.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: rear disc brakes on 84 Z/28
I believe the holes on the backing plate flange are different between the drum and disk models. You will probably need to do a little drilling
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
no Just pull the old stuff off pull the dif cover and pull the axles put the 02 backing plates on and reassemble you will need to use the parking brake cables off the 02
The mounting flange on the housing is completely different on drum/disc cars. You'll likely need to cut the flange, and drill mounting holes. Precise alignment may take shims. Brake bias will probably be wrong without modding the proportioning valve and/or master cylinder.
Axle/Gears: 10 Bolt 2.73 Open
I thought there was an aftermarket bracket you had to have to mount the LS brakes?
Some people have posted that they've just unbolted the LS1 rears and bolted them on the thirdgen drum rear after cutting the drum flange square and drilling a few holes. But it's also known that the axle tube outside diameter on disc and drum rears is different, discs being larger. So in theory anyway, the backing plate wouldn't be supported by the axle tube, but only by the bolts/flanges. Whether that matters... Who knows, GM must have thought it did. The other issue is centering the caliper on the rotor. Thirdgen disc rears use shims between the flange and backing plate. Most aftermarket setups shim between the caliper and bracket. I don't know how the LS1 setup is centered, might not matter. I'm just not sure I'd trust the quick conversion.
Car: 86 Firebird
Engine: 305 SBC
search invincible on you tube he has a video of him putting brakes off a 98 4th gen on his 68 Bird
BOTTLEDZ28
Brakes
Sep 16, 2012 02:09 PM
MrDude_1
Feb 20, 2004 10:18 PM
chekbaka
Nov 21, 2003 07:14 AM
FormulaJoe
May 15, 2001 11:27 AM
