Brake rotor and pad info needed
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Brake rotor and pad info needed
Stock replacement parts? I've used power stop rotors for 4th gen they seem good. I hear good things about EBC. If its simply a daily driver the parts house parts work pretty good. Just make sure you do a proper brake break in process. Others may disagree but there is only so much you can make the stock single piston brakes do without sinking money in an upgraded system.
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
I did EBCs my 4th gen very happy all the way around, they work great are quiet and minimal dust with NAPA premium pass, have not done my 3rd gen yer, price was good
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I am a fan of Powerstop. Used the complete kit including calipers on the Z an used the Pad and Drilled and slotted Rotors on my truck. Very happy with both, stops great and minimal dust.
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
https://www.thirdgen.org/forums/brak...attention.html
I am very happy with the results on the front. There are better kits for more money, but for plug and play and cost....
maksik7
Mar 25, 2002 06:56 PM
maksik7
Mar 25, 2002 05:24 PM
